LXD: Snap/4.3
I accidentally missed the B for GB adding a disk:
lxc config device add c1 root disk pool=default path=/ size=30G
Tried to start the container, it failed noting the invalid 30G value:
lxc start c1
Error: Common start logic: Failed to start device "root": Invalid value: 30G
Try `lxc info --show-log c1` for more info
Remove and correct the size:
lxc config device remove c1 root
lxc config device add c1 root disk pool=default path=/ size=30GB
Try to start the container, the 30G value is still cached somewhere and the container will not start.
lxc start c1
lxc config show c1 shows the valid value:
ipv4.address: xx
nictype: routed
parent: ens3
pool: default
Any ideas?
tomp
(Thomas Parrott)
2
Please can you show output of lxc config show c1 with and without the --expanded flag.
@tomp Aha. While editing the lxc configs for public consumption, I found the culprit:
volatile.root.apply_quota: 30G
lxc config show c1
image.architecture: amd64
image.description: ubuntu 18.04 LTS amd64 (release) (20200519.1)
image.label: release
image.os: ubuntu
image.release: bionic
image.serial: "20200519.1"
image.type: squashfs
image.version: "18.04"
volatile.base_image: 70d3dcaabcffb1aa1644d0ce866efcb141742179e94ad72aefb8d3502338a71f
volatile.eth0.hwaddr: 00:16:3e:d7:de:f0
volatile.eth0.name: eth0
volatile.idmap.base: "0"
ipv4.address: xx
nictype: routed
parent: ens3
pool: default
tomp
(Thomas Parrott)
4
Excellent. Seems like we have a validation issue there to fix.
stgraber
(Stéphane Graber)
5
Indeed LXD should have failed much earlier on this one. For now, the easy fix is to edit that apply_quota to 30GB.
tomp
(Thomas Parrott)
6
Have fixed the validation here:
Yes, resolved using:
lxc config edit c1
and changing
to
volatile.root.apply_quota: 30GB
Thanks for your help @tomp and @stgraber.
gaia
8
My VM reads volatile.root.apply_quota: "true"
, and the manual states it is of type string
not boolean
I changed it to false and the VM booted up.
LXD Version 4.0.8 on Ubuntu Focal, vm is from ubuntu:focal.
