Any help appreciated.
Issues:
- Can only create, start using sudo
- Containers will no longer start: lxc-start: test2: lxccontainer.c: wait_on_daemonized_start: 834 Received container state “STOPPING” instead of “RUNNING”
The container failed to start. - The container start error above is possibly linked to network failure; error below.
- Good up to date Mint tutorial? Graber’s page is great but not mint specific and some commands are deprecated.
System: “Linux Mint 18 Sarah”, LXC 3.01
More Information:
Just got lxc to work yesterday. Had to explicitly install apparmor because I was getting security errors but apparmor status tools did not exist. I thought this odd, and it may be relevant. Persevered, was able to debug and run containers. I’ve moved /var/lib/lxc to another drive via symbolic link for space issue reasons (planned number/size of containers). Again still able to run containers.
At some point I shut the machine down and when I came back I could not get containers, existing or new to start. I can still create containers using sudo but can not start them. Initially start errors were due to my own stupidity, -f not -F which gave failed to load rcfile, then due to some hidden change in lxc configuration.
- systemctl status lxc.service shows active (exited), same status as yesterday. Explicitly starting the service doesn’t change anything.
- lxc-checkconfig shows all enabled, green. No apparent differences from when containers would start and work.
Network Error in Logfile
$ sudo lxc-start -F -d -n test2 --logfile y.txt
To get more details, run the container in foreground mode.
Additional information can be obtained by setting the --logfile and --logpriority options.
$ cat y.txt
lxc-start test2 20180812140431.766 ERROR lxc_utils - utils.c:run_command:2280 - failed to exec command
lxc-start test2 20180812140431.767 ERROR lxc_network - network.c:lxc_ovs_attach_bridge:1893 - Failed to attach “lxcbr0” to openvswitch bridge “vethFAW5A2”: lxc-start: test2: utils.c: run_command: 2280 failed to exec comman
lxc-start test2 20180812140431.767 ERROR lxc_network - network.c:instantiate_veth:198 - Failed to attach “vethFAW5A2” to bridge “lxcbr0”: Operation not permitted
lxc-start test2 20180812140431.814 ERROR lxc_network - network.c:lxc_create_network_priv:2452 - Failed to create network device
lxc-start test2 20180812140431.814 ERROR lxc_start - start.c:lxc_spawn:1579 - Failed to create the network
lxc-start test2 20180812140431.814 ERROR lxc_start - start.c:__lxc_start:1887 - Failed to spawn container “test2”
lxc-start test2 20180812140431.814 ERROR lxc_container - lxccontainer.c:wait_on_daemonized_start:834 - Received container state “STOPPING” instead of “RUNNING”
