Hello to all, I have a strange situation.
After a failed lxc import (image to big for my default volume root size or an nonexistent storage volume attached to the original exported container, I’m sorry to not to be more precise but I discovered the problem after this two operation) I have a “ghost” storage volume.
1st failed operation: lxc import image_prod.tar.gz image_stage
2nd failed operation: lxc import image_prod.tar.gz image_stage
I see the ghost volume through lxc storage volume list default
, no volume trace with lvs
or lsblk
To delete it the only way is through lxd sql global "delete from storage_volumes where storage_volumes.id=6"
Thank you, Davide
lxc snap 4.11
storage LVM (xfs, no thinpool)
