wexi79
(Veikko Skurnik)
1
this operation is described in the LXD docs:
sudo truncate -s +5G /var/lib/lxd/zfs.img
sudo zpool set autoexpand=on lxd
sudo zpool online -e lxd /var/lib/lxd/zfs.img
sudo zpool set autoexpand=off lxd
Is it safe to perform it for a pool with containers or is there a possibility of losing container data?
stgraber
(Stéphane Graber)
2
It’s safe to do so long as you have enough space for it.
This can be done online while containers are running.
wexi79
(Veikko Skurnik)
3
Cool, thank you. Maybe this could be added to the documentation also?
simos
(Simos Xenitellis)
4
There is currently reference documentation for LXD.
That info would fit to a User Guide instead.
