I had initial issues with my install of ubuntu 18 so i swapped out the os disk and rebuilt it.
my original LXD build was in a ZFS file partition on a different datapool so when i rebuilt the system i did a “zfs import DATA” and have access to my snapshots / etc
when I ran “lxd init” on my new machine I tried to give it the dataset where the pool currently existed - DATA/LXD
however it told me it couldn’t use that pool because it was not empty so i used a new location DATA/LXC
How can I restore my containers?
edit: attempting to follow this
i mounted my container
zfs mount DATA/LXD/containers/piholeunifi
which worked
SERVER:/var/lib/lxd/storage-pools/default/containers/piholeunifi$ sudo ls
total 49K
11K drwx--x--x 4 165536 165536 6 Sep 30 10:05 .
4.0K drwxr-xr-x 3 root root 4.0K Oct 15 18:33 ..
6.0K -r-------- 1 root root 2.4K Oct 15 05:18 backup.yaml
6.0K -rw-r--r-- 1 root root 1.1K Sep 11 17:58 metadata.yaml
11K drwxr-xr-x 22 165536 165536 22 Sep 11 16:59 rootfs
11K drwxr-xr-x 2 root root 7 Sep 11 17:58 templates
sudo lxd import piholeunifi
Error: The container "piholeunifi" does not seem to exist on any storage pool
|MODERATION: Removed spam links, considering to remove the whole thread|
