How do you switch profiles on a container?
so i initially created a profile just to get lxc up and running
config: {}
    nictype: macvlan
    parent: enp4s0
    pool: default
everything was fine, it pulled an ip in my networks range and I was happy.
I then decided to put lxc containers in their own vlan so they aren’t on the same network as the host
config: {}
    nictype: macvlan
    parent: enp4s0.20
    pool: default
and that works, however when i
lxc profile remove pihole default
lxc profile assign pihole VLAN20
it’s still coming up with the old IP as well as the new IP (ignore the ip’s for now they will change)
 lxc list
|  NAME  |  STATE  |       IPV4       | IPV6 |    TYPE    | SNAPSHOTS |
| TEST   | RUNNING | 2.2.2.101 (eth0) |      | PERSISTENT | 0         |
| TEST2  | RUNNING | 2.2.2.102 (eth0) |      | PERSISTENT | 0         |
| pihole | RUNNING | 2.2.2.103 (eth0) |      | PERSISTENT | 0         |
|        |         | 10.1.10.5 (eth0) |      |            |           |
i can easily just blow away the server and create a new one… but when i’m a year down the road and want to change something in the profiles i don’t want to have to do that
Your profile looks good to me. We use a similar profile with VLANs:
config: {}
description: “”
nictype: macvlan
parent: eth0.201
eth1:
nictype: macvlan
parent: eth0.202
I think your problem may be the container itself. Can you spin up a new container with this profile to see if you get double NICs assigned?
yep, it was the container. when you set up pi-hole it tries to keep a static ip even though the original config was for dhcp.
