How network subject selectors like @internal and @external should work?
Can someone clarify how network subject selectors like @internal and @external are intended to work in ACLs? I had assumed that @internal would match sources and destinations within the Incus network, while @external would match sources and destinations outside the Incus network. However, my experiments are yielding unexpected results.
I’m testing this on a three-member Incus cluster with an OVN-type network:
root@incus-1:~# incus network ls | grep CREATED
| default        | ovn      | YES     | 10.47.57.1/24 | none |             | 4       | CREATED |
| uplink         | physical | YES     |               |      |             | 1       | CREATED |
There are three container instances foo, bar and baz:
# incus ls
| NAME |  STATE  |       IPV4        | IPV6 |   TYPE    | SNAPSHOTS | LOCATION |
| bar  | RUNNING | 10.47.57.3 (eth0) |      | CONTAINER | 0         | incus-2  |
| baz  | RUNNING | 10.47.57.4 (eth0) |      | CONTAINER | 0         | incus-3  |
| foo  | RUNNING | 10.47.57.2 (eth0) |      | CONTAINER | 0         | incus-1  |
Instances can reach internet and each other when no ACLs are involved:
root@foo:~# fping 10.47.57.3 10.47.57.4 8.8.8.8
10.47.57.3 is alive
10.47.57.4 is alive
8.8.8.8 is alive
When I add an ACL that should permit all egress traffic and only allow ingress traffic from internal addresses, I unexpectedly find that traffic between instances is blocked:
root@incus-1:~# incus network acl show default
egress:
- action: allow
  state: enabled
ingress:
- action: allow
  source: '@internal'
  state: enabled
config: {}
- /1.0/networks/default
project: default
ICMP Host Unreachable from 10.47.57.3 for ICMP Echo sent to 10.47.57.3
ICMP Host Unreachable from 10.47.57.4 for ICMP Echo sent to 10.47.57.4
8.8.8.8 is alive
10.47.57.3 is unreachable
10.47.57.4 is unreachable
Interestingly, if I replace ‘@internal’ with the explicit subnet ‘10.47.57.0/24’, internal traffic is restored:
egress:
- action: allow
  state: enabled
ingress:
- action: allow
  source: 10.47.57.0/24
  state: enabled
config: {}
project: default
10.47.57.3 is alive
10.47.57.4 is alive
8.8.8.8 is alive
Out of curiosity, I’ve also experimented with using selectors in egress rules. In some cases, the behavior matches my expectations:
egress:
- action: allow
  destination: '@internal'
  state: enabled
ingress:
- action: allow
  state: enabled
config: {}
project: default
10.47.57.3 is alive
10.47.57.4 is alive
ICMP Host Unreachable from 8.8.8.8 for ICMP Echo sent to 8.8.8.8
8.8.8.8 is unreachable
Some times not:
egress:
- action: allow
  destination: '@external'
  state: enabled
ingress:
- action: allow
  state: enabled
config: {}
project: default
10.47.57.3 is alive
10.47.57.4 is alive
8.8.8.8 is alive
I am experimenting on Ubuntu 24.04 with latest updates and LTS Incus from Zabbly repo:
root@incus-1:~# lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 24.04.1 LTS
Release:	24.04
Codename:	noble
root@incus-1:~# incus version
Client version: 6.0.2
Server version: 6.0.2
This sounds like a bug. It’d be great if you could test with Incus 6.6 though 6.0.2 should be pretty close.
Can you file this as a bug at Issues · lxc/incus · GitHub ?
I shall be traveling for the next two weeks, but once I’m back, I shall check if I can reproduce this with Incus 6.6.
2024-11-05, an, 07:47 Stéphane Graber via Linux Containers Forum <noreply@discuss.linuxcontainers.org> rašė:
@stgraber Just tried the same with the latest Incus v6.7:
root@incus-stable-1:~# incus version
Client version: 6.7
Server version: 6.7
Selectors work as expected.
Just in case I shall spin a new LTS cluster and see if I can reproduce this once more.
I take that back. Haven’t assigned a newly created ACL to a network, that’s why selectors were “working”.
So in short – selectors do not work for me neither with the latest stable v6.7, nor latest LTS 6.0.2 (re-tested just half an hour ago). Shall create an issue on GH some time tomorrow.
Issue #1423 created
