I would like to add 10 GB of unformatted disks to my running VMs that are running on Ubuntu 18.04.
I am not able to figure out the command. Any help putting it in the VM Profile?
No crossposting please.
As far as I know you can’t just add unformatted disks.
You can add folders, files or block devices.
See here: https://lxd.readthedocs.io/en/latest/instances/#type-disk
You can create volumes though:
https://lxd.readthedocs.io/en/latest/storage/#storage-volume-configuration
lxc storage volume
gives you an overview over all commands to manage volumes;
you can apply all keys that are listed in the above link.
Apologies. Thank you for the links.
