I confirm that the snapshot was new and taken after modification apply to the profile !
The first snap was done with the profile config
The second snap was done with the container config
I have recreate the container and tested it twice
Snapshots:
snap0 (taken at 2020/03/13 17:02 UTC) (stateless)
snap1 (taken at 2020/03/13 17:03 UTC) (expires at 2020/03/13 17:04 UTC) (stateless)
#lxc profile show default
snapshots.expiry: 2M
nictype: bridged
parent: br1
pool: local
- /1.0/instances/first
- /1.0/instances/lxdMosaic
- /1.0/instances/Jellyfin
- /1.0/instances/graylog3
- /1.0/instances/ns1
- /1.0/instances/bkp-aptcache
- /1.0/instances/bkp-checkmk
- /1.0/instances/bkp-graylog2
- /1.0/instances/bkp-ns2
- /1.0/instances/bkp-plex
- /1.0/instances/bkp-unify
- /1.0/instances/bkp-xwiki
- /1.0/instances/bkp-gui1804
- /1.0/instances/test
#lxc launch ubuntu: test
Creating test
Starting test
#lxc config show --expanded test
image.architecture: amd64
image.description: ubuntu 18.04 LTS amd64 (release) (20200218)
image.label: release
image.os: ubuntu
image.release: bionic
image.serial: ā20200218ā
image.type: squashfs
image.version: ā18.04ā
volatile.base_image: 8c4e87e53c024e0449003350f0b0626b124b68060b73c0a7ad9547670e00d4b3
volatile.eth0.host_name: veth0d963311
volatile.eth0.hwaddr: 00:16:3e:db:d5:7e
volatile.idmap.base: ā0ā
volatile.idmap.current: ā[{āIsuidā:true,āIsgidā:false,āHostidā:1000000,āNsidā:0,āMaprangeā:1000000000},{āIsuidā:false,āIsgidā:true,āHostidā:1000000,āNsidā:0,āMaprangeā:1000000000}]ā
volatile.idmap.next: ā[{āIsuidā:true,āIsgidā:false,āHostidā:1000000,āNsidā:0,āMaprangeā:1000000000},{āIsuidā:false,āIsgidā:true,āHostidā:1000000,āNsidā:0,āMaprangeā:1000000000}]ā
volatile.last_state.idmap: ā[{āIsuidā:true,āIsgidā:false,āHostidā:1000000,āNsidā:0,āMaprangeā:1000000000},{āIsuidā:false,āIsgidā:true,āHostidā:1000000,āNsidā:0,āMaprangeā:1000000000}]ā
nictype: bridged
parent: br1
pool: local
description: āā
# lxc snapshot test
# lxc info test
Remote: unix://
Created: 2020/03/13 17:07 UTC
Status: Running
Type: container
Profiles: default
Pid: 24243
Ips:
eth0: inet 192.168.1.187 veth0d963311
lo: inet 127.0.0.1
Resources:
Processes: 24
Disk usage:
root: 7.40MB
CPU usage:
CPU usage (in seconds): 12
Memory usage:
Memory (current): 130.11MB
Network usage:
Bytes received: 225.31kB
Bytes sent: 4.32kB
Packets received: 1000
Packets sent: 36
lo:
Bytes received: 1.29kB
Bytes sent: 1.29kB
Packets received: 16
Packets sent: 16
Snapshots:
- snap0 (taken at 2020/03/13 17:10 UTC) (stateless)*
