Hi ,
i have zfs file system installed on my OS , i have done lxd init and selected ZFS as a filesystem you can see the options i have selected while lxd init.
root@prod:/etc/apt# lxd init
Would you like to use LXD clustering? (yes/no) [default=no]:
Name of the storage backend to use (btrfs, dir, lvm, zfs, ceph) [default=zfs]:
Create a new ZFS pool? (yes/no) [default=yes]:
Would you like to use an existing empty disk or partition? (yes/no) [default=no]:
Size in GB of the new loop device (1GB minimum) [default=30GB]: 460GB
Would you like to create a new local network bridge? (yes/no) [default=yes]:
What should the new bridge be called? [default=lxdbr0]:
Would you like LXD to be available over the network? (yes/no) [default=no]:
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]
Would you like a YAML “lxd init” preseed to be printed? (yes/no) [default=no]:
now i want to assign 25gb to each container whenever i launch new container it should be created with the 25gb limit . is there any command to set the limit so that i can incorporate that command in my lxc launching bash script so that whenever new container launches it will launch with 25gb disk limit.
