I have an LXD container locally for more than one month with a lot of configs, two disks (one for docker and one for root from 2 different storage pools /dev/sdb
and /dev/sdc
) and one proxy, and also 3 different profiles. I am looking for the simplest approach that helps me to backup (or move) this container entirely to another machine (with all disks, proxy, volumes, and …).
I found 3 approaches so far:
- move command
- export command
- create an image and create a new container from it on the new machine
I personally like the move command more but my question is does this command move a container with all disks, proxy, volumes, and … ? if not how can I configure it, or what is the solution?
