I’m going to use a remote lxd exclusively for my lxd-client, so I set my default remote lxc remote set-default
to that remote endpoint, things work fine, so far so good. I’m not sure why I’ve never run this way before, it works way nicer for my use case.
anyway I’d also like to remove/cleanup my local storage, since my zfs loopback FS is taking up 17G of storage (since you can’t shrink ZFS). How do I delete this correctly?
dpb@bierstadt:~[]$ sudo ls -l /var/snap/lxd/common/lxd/disks
total 18489396
-rw------- 1 root root 19327352832 May 15 21:29 default.img
-rw------- 1 root root 19327352832 Apr 17 05:46 juju-btrfs.img
-rw------- 1 root root 19327352832 May 15 21:27 juju-zfs.img
