I have a bunch of containers getting IPs via DHCP over MACVLAN and everything works great, but I can’t access them from the host. @Simos’ excellent and extraordinarily useful blog says this is possible, but the page he links is from 2012 and doesn’t work with netplan and the new “ip” command.
Does anyone have a clear-cut easy to follow tutorial to do this in Ubuntu 18.04? My google-fu has failed me there, even though it seems like this would be a pretty common question! I tried adding a second IP to my host interface via ip addr add and then setting static routes over it but this did not work.
Network config:
config: {}
type: physical
- /1.0/containers/plex
managed: false
status: ""
locations: []
Container config:
boot.autostart: "true"
image.architecture: amd64
image.description: ubuntu 18.04 LTS amd64 (release) (20180724)
image.label: release
image.os: ubuntu
image.release: bionic
image.serial: "20180724"
image.version: "18.04"
raw.lxc: lxc.cgroup.devices.allow=a
security.privileged: "true"
volatile.base_image: 38219778c2cf02521f34f950580ce3af0e4b61fbaf2b4411a7a6c4f0736071f9
volatile.eth0.hwaddr: 00:16:3e:42:e5:dd
volatile.idmap.base: "0"
volatile.idmap.next: '[]'
nas:
path: /nas
source: /media/Nastassia
And profile:
environment.TZ: America/New_York
nictype: macvlan
parent: eno1
pool: zfspool
