The expected
lxc storage create default lvm lvm.thinpool_name=lvdata lvm.vg_name=vghdd lvm.use_thinpool=true
fails with the
Error: LXD already uses volume group "vghdd" for pool "default"
while LXD certainly does not use it - it’s a new LXD installation and
lxd sql "select * from storage_pools_config"
certainly returns nothing.
vghdd
volume group exists, lvdata
thinpool exists. lvdata
is not empty - there are couple volumes created there already, but it was not a problem for lxd v2.x
From the other hand, if I specify the non existing thinpool name:
# lxc storage create default lvm lvm.vg_name=vghdd lvm.thinpool_name=lvlxd lvm.use_thinpool=true
Error: volume group "vghdd" is not empty
What am I doing wrong?
