Hello, I’m using Debian 13 (Stable) with Incus 7.0.1 (backports)
I try following commands (either for container or virtual machine). Guest takes expected IP address (DHCP client) but DNS is assumed to be bridge’s IP address (192.168.2.1):
The bridge dns.nameservers setting applies to every guest on that network. For a different resolver per container, set it inside that guest rather than on the shared Incus network.
The easy answer is to have multiple incus networks (since they can have different DNS settings), and create your containers on the corresponding network.
The incus DHCP server is dnsmasq, which is minimal and lightweight - or not very well featured, whichever way you look at it.
If you want to give out different DHCP options to different clients on the same network, you’ll need a more heavyweight DHCP server like ISC KEA. And you will have to identify the clients somehow (e.g. by MAC address, or by some option in the DHCP client request)
In principle you could run your own DHCP server in its own container. I’m not entirely sure if you can turn off the incus-provided DHCP server on a given network; if you cannot, then simply use an unmanaged network (a bridge which you create on the host, e.g. with netplan)
However, you’d still be 100% responsible for managing DHCP entries for all your containers. I think it would likely be much less effort to apply static IP and DNS settings to all your containers, e.g. using cloud-init.
