We are running containers ip 240...140 and one of the application is running in port 9999.
Lxd is install in 192.168.0.23 server.
How can i use container application in browser?How to map?
Can you please guide.
Thanks
Thanks
Take a look at the proxy device type that allows you to map port(s) from the host’s IP into the container.
https://linuxcontainers.org/lxd/docs/master/instances#type-proxy
Ok,Thank you
