Next, I tried to copy my-image
(private) from the project foo
from the remote to the client:
lxc image copy my-lxd-server:my-image local:
Error: Failed remote image download:
- https://10.147.96.1:8443: Failed to connect to LXD server "https://10.147.96.1:8443": Get "https://10.147.96.1:8443/1.0": Unable to connect to: 10.147.96.1:8443
- https://[fd42:8342:9885:2003::1]:8443: Failed to connect to LXD server "https://[fd42:8342:9885:2003::1]:8443": Get "https://[fd42:8342:9885:2003::1]:8443/1.0": Unable to connect to: [fd42:8342:9885:2003::1]:8443
- https://192.168.199.131:8443: not found
I’ve found older threads in this forum that described problems when copying private images but nothing recent nor open issues on Github.
According to the output of lxc image copy my-lxd-server:my-image local: --debug
, the client can find the remote at 10.147.96.1, connect to it, resolve the alias my-image
, request a download token and start the download …
DBUG[06-14|12:42:19] Connecting to a remote LXD over HTTPs
DBUG[06-14|12:42:19] Sending request to LXD method=GET url=https://192.168.199.131:8443/1.0 etag=
DBUG[06-14|12:42:19] Got response struct from LXD
"config": null,
"api_extensions": [
"storage_zfs_remove_snapshots",
"container_host_shutdown_timeout",
"container_stop_priority",
"container_syscall_filtering",
"auth_pki",
"container_last_used_at",
"etag",
"patch",
"usb_devices",
"https_allowed_credentials",
"image_compression_algorithm",
"directory_manipulation",
"container_cpu_time",
"storage_zfs_use_refquota",
"storage_lvm_mount_options",
"network",
"profile_usedby",
"container_push",
"container_exec_recording",
"certificate_update",
"container_exec_signal_handling",
"gpu_devices",
"container_image_properties",
"migration_progress",
"id_map",
"network_firewall_filtering",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_dhcp_expiry",
"storage_lvm_vg_rename",
"storage_lvm_thinpool_rename",
"network_vlan",
"image_create_aliases",
"container_stateless_copy",
"container_only_migration",
"storage_zfs_clone_copy",
"unix_device_rename",
"storage_lvm_use_thinpool",
"storage_rsync_bwlimit",
"network_vxlan_interface",
"storage_btrfs_mount_options",
"entity_description",
"image_force_refresh",
"storage_lvm_lv_resizing",
"id_map_base",
"file_symlinks",
"container_push_target",
"network_vlan_physical",
"storage_images_delete",
"container_edit_metadata",
"container_snapshot_stateful_migration",
"storage_driver_ceph",
"storage_ceph_user_name",
"resource_limits",
"storage_volatile_initial_source",
"storage_ceph_force_osd_reuse",
"storage_block_filesystem_btrfs",
"resources",
"kernel_limits",
"storage_api_volume_rename",
"macaroon_authentication",
"network_sriov",
"console",
"restrict_devlxd",
"migration_pre_copy",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"network_dhcp_gateway",
"file_get_symlink",
"network_leases",
"unix_device_hotplug",
"storage_api_local_volume_handling",
"operation_description",
"clustering",
"event_lifecycle",
"storage_api_remote_volume_handling",
"nvidia_runtime",
"container_mount_propagation",
"container_backup",
"devlxd_images",
"container_local_cross_pool_handling",
"proxy_unix",
"proxy_udp",
"clustering_join",
"proxy_tcp_udp_multi_port_handling",
"network_state",
"proxy_unix_dac_properties",
"container_protection_delete",
"unix_priv_drop",
"pprof_http",
"proxy_haproxy_protocol",
"network_hwaddr",
"proxy_nat",
"network_nat_order",
"container_full",
"candid_authentication",
"backup_compression",
"candid_config",
"nvidia_runtime_config",
"storage_api_volume_snapshots",
"storage_unmapped",
"projects",
"candid_config_key",
"network_vxlan_ttl",
"container_incremental_copy",
"usb_optional_vendorid",
"snapshot_scheduling",
"snapshot_schedule_aliases",
"container_copy_project",
"clustering_server_address",
"clustering_image_replication",
"container_protection_shift",
"snapshot_expiry",
"container_backup_override_pool",
"snapshot_expiry_creation",
"network_leases_location",
"resources_cpu_socket",
"resources_gpu",
"resources_numa",
"kernel_features",
"id_map_current",
"event_location",
"storage_api_remote_volume_snapshots",
"network_nat_address",
"container_nic_routes",
"rbac",
"cluster_internal_copy",
"seccomp_notify",
"lxc_features",
"container_nic_ipvlan",
"network_vlan_sriov",
"storage_cephfs",
"container_nic_ipfilter",
"resources_v2",
"container_exec_user_group_cwd",
"container_syscall_intercept",
"container_disk_shift",
"storage_shifted",
"resources_infiniband",
"daemon_storage",
"instances",
"image_types",
"resources_disk_sata",
"clustering_roles",
"images_expiry",
"resources_network_firmware",
"backup_compression_algorithm",
"ceph_data_pool_name",
"container_syscall_intercept_mount",
"compression_squashfs",
"container_raw_mount",
"container_nic_routed",
"container_syscall_intercept_mount_fuse",
"container_disk_ceph",
"virtual-machines",
"image_profiles",
"clustering_architecture",
"resources_disk_id",
"storage_lvm_stripes",
"vm_boot_priority",
"unix_hotplug_devices",
"api_filtering",
"instance_nic_network",
"clustering_sizing",
"firewall_driver",
"projects_limits",
"container_syscall_intercept_hugetlbfs",
"limits_hugepages",
"container_nic_routed_gateway",
"projects_restrictions",
"custom_volume_snapshot_expiry",
"volume_snapshot_scheduling",
"trust_ca_certificates",
"snapshot_disk_usage",
"clustering_edit_roles",
"container_nic_routed_host_address",
"container_nic_ipvlan_gateway",
"resources_usb_pci",
"resources_cpu_threads_numa",
"resources_cpu_core_die",
"api_os",
"container_nic_routed_host_table",
"container_nic_ipvlan_host_table",
"container_nic_ipvlan_mode",
"resources_system",
"images_push_relay",
"network_dns_search",
"container_nic_routed_limits",
"instance_nic_bridged_vlan",
"network_state_bond_bridge",
"usedby_consistency",
"custom_block_volumes",
"clustering_failure_domains",
"resources_gpu_mdev",
"console_vga_type",
"projects_limits_disk",
"network_type_macvlan",
"network_type_sriov",
"container_syscall_intercept_bpf_devices",
"network_type_ovn",
"projects_networks",
"projects_networks_restricted_uplinks",
"custom_volume_backup",
"backup_override_name",
"storage_rsync_compression",
"network_type_physical",
"network_ovn_external_subnets",
"network_ovn_nat",
"network_ovn_external_routes_remove",
"tpm_device_type",
"storage_zfs_clone_copy_rebase",
"gpu_mdev",
"resources_pci_iommu",
"resources_network_usb",
"resources_disk_address",
"network_physical_ovn_ingress_mode",
"network_ovn_dhcp",
"network_physical_routes_anycast",
"projects_limits_instances",
"network_state_vlan",
"instance_nic_bridged_port_isolation",
"instance_bulk_state_change",
"network_gvrp",
"instance_pool_move",
"gpu_sriov",
"pci_device_type",
"storage_volume_state",
"network_acl",
"migration_stateful",
"disk_state_quota",
"storage_ceph_features",
"projects_compression",
"projects_images_remote_cache_expiry",
"certificate_project",
"network_ovn_acl",
"projects_images_auto_update",
"projects_restricted_cluster_target",
"images_default_architecture",
"network_ovn_acl_defaults",
"gpu_mig",
"project_usage",
"network_bridge_acl",
"warnings",
"projects_restricted_backups_and_snapshots",
"clustering_join_token",
"clustering_description",
"server_trusted_proxy"
"api_status": "stable",
"api_version": "1.0",
"auth": "trusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": [
"192.168.199.131:8443",
"10.147.96.1:8443",
"[fd42:8342:9885:2003::1]:8443"
"architectures": [
"x86_64",
"i686"
"certificate": "-----BEGIN CERTIFICATE-----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\nKtNA\n-----END CERTIFICATE-----\n",
"certificate_fingerprint": "2ac0e709d7a892490b13cc608aa2df79058392a338ea0cf52956c3f3a952427f",
"driver": "qemu | lxc",
"driver_version": "5.2.0 | 4.0.9",
"firewall": "nftables",
"kernel": "Linux",
"kernel_architecture": "x86_64",
"kernel_features": {
"netnsid_getifaddrs": "true",
"seccomp_listener": "true",
"seccomp_listener_continue": "true",
"shiftfs": "false",
"uevent_injection": "true",
"unpriv_fscaps": "true"
"kernel_version": "5.4.0-73-generic",
"lxc_features": {
"cgroup2": "true",
"devpts_fd": "true",
"idmapped_mounts_v2": "false",
"mount_injection_file": "true",
"network_gateway_device_route": "true",
"network_ipvlan": "true",
"network_l2proxy": "true",
"network_phys_macvlan_mtu": "true",
"network_veth_router": "true",
"pidfd": "true",
"seccomp_allow_deny_syntax": "true",
"seccomp_notify": "true",
"seccomp_proxy_send_notify_fd": "true"
"os_name": "Ubuntu",
"os_version": "20.04",
"project": "default",
"server": "lxd",
"server_clustered": false,
"server_name": "lxdserver",
"server_pid": 26712,
"server_version": "4.15",
"storage": "btrfs",
"storage_version": "4.15.1"
DBUG[06-14|12:42:19] Connecting to a local LXD over a Unix socket
DBUG[06-14|12:42:19] Sending request to LXD method=GET url=http://unix.socket/1.0 etag=
"config": {
"core.trust_ca_certificates": "true"
"api_extensions": [
"auth_pki",
"etag",
"patch",
"usb_devices",
"network",
"profile_usedby",
"container_push",
"gpu_devices",
"id_map",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_vlan",
"id_map_base",
"file_symlinks",
"resource_limits",
"resources",
"kernel_limits",
"network_sriov",
"console",
"restrict_devlxd",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"file_get_symlink",
"network_leases",
"clustering",
"event_lifecycle",
"nvidia_runtime",
"container_backup",
"devlxd_images",
"proxy_unix",
"proxy_udp",
"clustering_join",
"network_state",
"unix_priv_drop",
"pprof_http",
"network_hwaddr",
"proxy_nat",
"container_full",
"candid_config",
"storage_unmapped",
"projects",
"snapshot_expiry",
"resources_gpu",
"resources_numa",
"kernel_features",
"id_map_current",
"event_location",
"rbac",
"seccomp_notify",
"lxc_features",
"storage_cephfs",
"resources_v2",
"storage_shifted",
"daemon_storage",
"instances",
"image_types",
"clustering_roles",
"images_expiry",
"virtual-machines",
"image_profiles",
"vm_boot_priority",
"api_filtering",
"firewall_driver",
"projects_limits",
"limits_hugepages",
"api_os",
"resources_system",
"console_vga_type",
"network_type_ovn",
"network_ovn_nat",
"tpm_device_type",
"gpu_mdev",
"network_ovn_dhcp",
"network_gvrp",
"gpu_sriov",
"pci_device_type",
"network_acl",
"disk_state_quota",
"network_ovn_acl",
"gpu_mig",
"project_usage",
"warnings",
"auth": "trusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": [],
"architectures": [
"x86_64",
"i686"
"certificate": "-----BEGIN CERTIFICATE-----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\nArz+Esb1ItZvzCpfTJ7oaNRh13BUbySc1jJEKBYiiolbstgRVCXt\n-----END CERTIFICATE-----\n",
"certificate_fingerprint": "cc2527284ed0c26eecd230d0882797609b7eb20e4787352ec020df22532a31db",
"driver": "lxc | qemu",
"driver_version": "4.0.9 | 5.2.0",
"kernel": "Linux",
"shiftfs": "false",
"kernel_version": "5.8.0-53-generic",
"lxc_features": {
"cgroup2": "true",
"pidfd": "true",
"server": "lxd",
"server_name": "ubuntu",
"server_pid": 136688,
"storage": "btrfs",
DBUG[06-14|12:42:19] Sending request to LXD method=GET url="https://192.168.199.131:8443/1.0/images/aliases/my-image?project=foo" etag=
"description": "",
"target": "e096be4e1d497891a08763e33a94f6d4bb785c47b69d24cc0a746dcc576a5fda",
"name": "my-image",
"type": "container"
DBUG[06-14|12:42:19] Sending request to LXD method=GET url="https://192.168.199.131:8443/1.0/images/e096be4e1d497891a08763e33a94f6d4bb785c47b69d24cc0a746dcc576a5fda?project=foo" etag=
"auto_update": false,
"properties": {
"architecture": "amd64",
"description": "Alpine 3.13 amd64 (20210613_13:00)",
"os": "Alpine",
"release": "3.13",
"serial": "20210613_13:00",
"type": "squashfs",
"variant": "default"
"public": false,
"expires_at": "1970-01-01T00:00:00Z",
"profiles": [
"default"
"aliases": [
"name": "my-image",
"description": ""
"architecture": "x86_64",
"cached": false,
"filename": "lxd.tar.xz",
"fingerprint": "e096be4e1d497891a08763e33a94f6d4bb785c47b69d24cc0a746dcc576a5fda",
"size": 2564996,
"update_source": {
"alias": "alpine/3.13/amd64",
"certificate": "",
"protocol": "simplestreams",
"server": "https://images.linuxcontainers.org",
"image_type": ""
"type": "container",
"created_at": "2021-06-13T00:00:00Z",
"last_used_at": "0001-01-01T00:00:00Z",
"uploaded_at": "2021-06-14T15:13:46.763604717Z"
DBUG[06-14|12:42:19] Connected to the websocket: wss://192.168.199.131:8443/1.0/events?project=foo
DBUG[06-14|12:42:19] Sending request to LXD method=POST url="https://192.168.199.131:8443/1.0/images/e096be4e1d497891a08763e33a94f6d4bb785c47b69d24cc0a746dcc576a5fda/secret?project=foo" etag=
DBUG[06-14|12:42:19] Got operation from LXD
"id": "20c7d399-2444-450b-b7e8-034c69ffd33d",
"class": "token",
"description": "Image download token",
"created_at": "2021-06-14T19:42:19.327763697Z",
"updated_at": "2021-06-14T19:42:19.327763697Z",
"status": "Running",
"status_code": 103,
"resources": {
"images": [
"/1.0/images/e096be4e1d497891a08763e33a94f6d4bb785c47b69d24cc0a746dcc576a5fda"
"metadata": {
"secret": "9a5b433dc4e3806d628eadda1b5e493db4fca29317009ea3434e35a1cc0612e6"
"may_cancel": true,
"err": "",
"location": "none"
DBUG[06-14|12:42:19] Connected to the websocket: ws://unix.socket/1.0/events
DBUG[06-14|12:42:19] Sending request to LXD method=POST url=http://unix.socket/1.0/images etag=
"properties": null,
"public": false,
"expires_at": "0001-01-01T00:00:00Z",
"profiles": null,
"filename": "",
"source": {
"alias": "",
"protocol": "lxd",
"server": "https://192.168.199.131:8443",
"image_type": "",
"mode": "pull",
"type": "image",
"url": "",
"name": "",
"compression_algorithm": "",
"aliases": null
"id": "c2e34e8e-94a4-4d7a-a50e-9bfa9ed33e41",
"class": "task",
"description": "Downloading image",
"created_at": "2021-06-14T12:42:19.333924991-07:00",
"updated_at": "2021-06-14T12:42:19.333924991-07:00",
"status_code": 103,
"resources": null,
"metadata": null,
"may_cancel": false,
"err": "",
"location": "none"
DBUG[06-14|12:42:19] Sending request to LXD method=GET url=http://unix.socket/1.0/operations/c2e34e8e-94a4-4d7a-a50e-9bfa9ed33e41 etag=
"class": "task",
"status_code": 103,
"resources": null,
"metadata": null,
"err": "",
"location": "none"
"properties": null,
"public": false,
"profiles": null,
"filename": "",
"source": {
"alias": "",
"protocol": "lxd",
"server": "https://10.147.96.1:8443",
"image_type": "",
"mode": "pull",
"type": "image",
"url": "",
"name": "",
"aliases": null
"id": "ca461a8e-9d40-47d6-8a36-fe4b83d9e056",
"class": "task",
"created_at": "2021-06-14T12:42:19.388906446-07:00",
"updated_at": "2021-06-14T12:42:19.388906446-07:00",
"status_code": 103,
"resources": null,
"metadata": null,
"err": "",
"location": "none"
DBUG[06-14|12:42:19] Sending request to LXD method=GET url=http://unix.socket/1.0/operations/ca461a8e-9d40-47d6-8a36-fe4b83d9e056 etag=
"class": "task",
"status_code": 103,
"resources": null,
"metadata": null,
"err": "",
"location": "none"
DBUG[06-14|12:42:39] Sending request to LXD method=POST url=http://unix.socket/1.0/images etag=
"properties": null,
"public": false,
"profiles": null,
"filename": "",
"source": {
"alias": "",
"protocol": "lxd",
"server": "https://[fd42:8342:9885:2003::1]:8443",
"image_type": "",
"mode": "pull",
"type": "image",
"url": "",
"name": "",
"aliases": null
DBUG[06-14|12:42:39] Got operation from LXD
"id": "260439dd-ebdf-45bf-ae2f-013b40d77a35",
"class": "task",
"created_at": "2021-06-14T12:42:39.408774736-07:00",
"updated_at": "2021-06-14T12:42:39.408774736-07:00",
"status_code": 103,
"resources": null,
"metadata": null,
"err": "",
"location": "none"
DBUG[06-14|12:42:39] Sending request to LXD method=GET url=http://unix.socket/1.0/operations/260439dd-ebdf-45bf-ae2f-013b40d77a35 etag=
DBUG[06-14|12:42:39] Got response struct from LXD
"class": "task",
"status_code": 103,
"resources": null,
"metadata": null,
"err": "",
"location": "none"
