This is very strange.
Incoming network works only for containers created after upgrade to LXD 4
I cant access via network macvlan or bridged nic but outgoing is working.
I use Ubuntu 18.04 for host and containers
I am desperate - cant see differences beetween new and old containers
lxc copy of old container not working too!
We will need to see your configuration before being able to advise.
Please can you provide the output of:
lxc config show <container> --expanded
Additionally please can you further describe the problem you are experiencing, i.e show specific commands that you would expect to work that do not anymore.
$ ip a
inet6 ::1/128 scope host
11: eth0@if12: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:bc:ca:55 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.34.150.64/24 brd 10.34.150.255 scope global dynamic eth0
valid_lft 3469sec preferred_lft 3469sec
inet6 fd42:18f9:aab8:4a5:216:3eff:febc:ca55/64 scope global dynamic mngtmpaddr noprefixroute
inet6 fe80::216:3eff:febc:ca55/64 scope link
13: eth1@if14: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:ca:1a:cb brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.168.188.86/24 brd 10.168.188.255 scope global dynamic eth1
inet6 fd42:f17e:a583:3af3:216:3eff:feca:1acb/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 3596sec preferred_lft 3596sec
inet6 fe80::216:3eff:feca:1acb/64 scope link
$ ip r
default via 94.130.143.1 dev enp0s31f6 proto static onlink
10.34.150.0/24 dev lxdbr0 proto kernel scope link src 10.34.150.1
10.168.188.0/24 dev localbr0 proto kernel scope link src 10.168.188.1
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.19.0.0/16 dev br-444234cecc2c proto kernel scope link src 172.19.0.1 linkdown
$ ip r
default via 10.34.150.1 dev eth0 proto dhcp src 10.34.150.64 metric 100
default via 10.168.188.1 dev eth1 proto dhcp src 10.168.188.86 metric 100
The presence of 2 default routes with the same metric value is likely to cause unintended networking problems, can you explain why you have this configuration?
That 2nd NIC, using DHCP with a default gateway is likely going to cause issues for you. I’m not clear why you need that for the bridged container, as bridged devices can communicate with the host.
Either way, I would suggest disabling DHCP on the 2nd NIC and using static configuration (or modifying the 2nd DHCP server so that it doesn’t configure a default gateway), such that there is no 2nd default gateway added.
Its likely that return packets are going out of the wrong interface.
Well I use secondary network to communicate macvlan with other containers and HOST himself.
How can I disable DHCP for sec network without removing network itself?
I upgraded containers/host and now I can use in netplan config metric!
Now it works
Thank you very very much for pointing me into right direction
