Hi guys,
I have been using lxc containers for quite a long time, but a rarely need to manage them, usually, just do start/stop/list. So I pretty much like a newbie. I see o lot of explanation on zfs, profiles, pools, storage, but I am not being able to compile all this information together. I need to increase my containers disk space.
My containers have about 23GB when I check df -h from inside a container:
ubuntu@localstorageserver:~$ df -h
default/containers/localstorageserver 23G 1.9G 21G 9% /
none 492K 4.0K 488K 1% /dev
tmpfs 100K 0 100K 0% /dev/lxd
tmpfs 100K 0 100K 0% /dev/.lxd-mounts
tmpfs 32G 0 32G 0% /dev/shm
tmpfs 13G 216K 13G 1% /run
tmpfs 6.3G 16K 6.3G 1% /run/user/1000
And I understand such conatiners were created using the default
profile that was configured during lxc init
ubuntu@dev24-vm:~$ lxc storage info default
info:
driver: zfs
space used: 7.11GiB
total space: 28.58GiB
used by:
images:
- 2e1e06db4f0a16090139689f1942499d453bab5fa7e3382e790ca08288147097
instances:
- backend
- configurationserver
- frontend
- localstorageserver
- maestroserver
- mentorserver
- messagebroker
- recorderserver
- remotecluster
- timeserver
So my questions are:
Does all my containers share those
, or each container has its owntotal space: 28.58GiB
How do I increase space in such condition?
PS: My host partition that hold the containers is about 400GB and just 8% used.
