I have two LXD servers running, one production (A) and one used for backups (B). On B I added A as a remote
example.com | https://example.com:4443 | lxd | tls | NO | NO |
Both severs are running:
core 16-2.37.1 6350 stable canonical✓ core
lxd 3.18 12224 stable canonical✓ -
and BTRFS is used as a storage backend.
Now, on B I can do something like this copy example.com:cont01/snapshot cont01
which is working fine.
Since a cron is running hourly to take the snapshots on A , there are a few changes but the copy transfers always the full snapshot
How can I transfer the snapshots incrementally? I read about a flag --refresh
but this doesn’t seem to work
Error: unknown flag: --refresh
Some containers are > 50GB thus so the snapshots, transferring them to B always takes hours.
Is there a better way to achieve this with the native LXD/BTRFS capabilities?
stgraber
(Stéphane Graber)
November 3, 2019, 12:36am
2
lxc copy
should have a --refresh
option which works when copying the entire container again, synchronizing the state of snapshots. LXD 3.18 supports it for sure, but maybe one of your servers is on an older release or has a mix of snap/deb causing this confusion?
You may want to run lxc version
@stgraber thanks your quick reply.
Here is the output from both servers:
Server A:
core 16-2.42 7917 stable canonical* core
lxd 3.18 12224 stable canonical* -
core.https_address: '[::]:4443'
core.trust_password: true
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses:
- 176.xxx.xxx.xxx:4443
- 10.159.23.1:4443
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
certificate_fingerprint: **************
driver: lxc
driver_version: 3.2.1
kernel: Linux
kernel_architecture: x86_64
kernel_features:
netnsid_getifaddrs: "false"
seccomp_listener: "false"
shiftfs: "false"
uevent_injection: "false"
unpriv_fscaps: "true"
kernel_version: 4.15.0-65-generic
lxc_features:
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
seccomp_notify: "true"
project: default
server: lxd
server_clustered: false
server_name: ****-prd
server_pid: 2268
server_version: "3.18"
storage: btrfs
storage_version: "4.4"
Server B:
snap list
config: {}
api_extensions:
- auth_pki
- etag
- patch
- usb_devices
- network
- profile_usedby
- container_push
- gpu_devices
- id_map
- network_routes
- storage
- file_delete
- file_append
- network_vlan
- id_map_base
- file_symlinks
- resource_limits
- resources
- kernel_limits
- network_sriov
- console
- restrict_devlxd
- infiniband
- maas_network
- devlxd_events
- proxy
- file_get_symlink
- network_leases
- clustering
- event_lifecycle
- nvidia_runtime
- candid_config
- candid_config_key
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses: []
architectures:
- x86_64
- i686
certificate: |
driver: lxc
driver_version: 3.0.3
kernel: Linux
kernel_version: 4.15.0-66-generic
server: lxd
server_pid: 1868
server_version: 3.0.3
storage: btrfs
storage_version: 4.15.1
server_name: ***-bckp
project: ""
stgraber
(Stéphane Graber)
November 4, 2019, 12:24am
4
Server B shows 3.0.3
which suggests it’s not actually using the snap.
You may have a combination of the deb and snap on that system.
If that’s the case lxd.migrate
should be able to move the data over to the snap and remove the remaining deb packages.
Thats odd, I’ve clean installed 18.04.03 which by default installs the lxd deb packages:
dpkg -l | grep lxd
ii lxd 3.0.3-0ubuntu1~18.04.1 amd64 Container hypervisor based on LXC - daemon
ii lxd-client 3.0.3-0ubuntu1~18.04.1 amd64 Container hypervisor based on LXC - client
Isn’t snap the preferred way to deploy LXD?
Thank you for pointing this out. I’ll remove the deb packages.
stgraber
(Stéphane Graber)
November 5, 2019, 3:50am
6
It is the preferred way to install LXD and the only way available on 18.10 and higher, 18.04 still has the deb available though as you’ve noticed
