INCUS 6.2 not create DHCP an instances
Thanks for the support and help in all moment.
I have an incus default profile
incus profile show default
config: {}
    network: incusbr2
    pool: default
- /1.0/instances/fail
- /1.0/instances/tes
- /1.0/instances/prue
project: default
the network is
incus network show incusbr2
  ipv4.address: 10.161.53.1/24
  ipv4.dhcp: "true"
  ipv4.nat: "true"
  ipv6.address: fd42:9170:59ba:aa87::1/64
  ipv6.nat: "true"
type: bridge
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
project: default
and my instances
incus list
| NAME |  STATE  | IPV4 |                     IPV6                      |   TYPE    | SNAPSHOTS |
| fail | RUNNING |      | fd42:9170:59ba:aa87:216:3eff:fe4d:8fff (eth0) | CONTAINER | 0         |
| prue | RUNNING |      | fd42:9170:59ba:aa87:216:3eff:fe74:dfe9 (eth0) | CONTAINER | 0         |
| tes  | RUNNING |      | fd42:9170:59ba:aa87:216:3eff:fe81:27b9 (eth0) | CONTAINER | 0         |
the problem is in IPV4, when I create instance, this not have IP, and when on an instance
incus exec tes -- ip a
    inet6 ::1/128 scope host
7: eth0@if8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 00:16:3e:81:27:b9 brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet6 fd42:9170:59ba:aa87:216:3eff:fe81:27b9/64 scope global mngtmpaddr noprefixroute
    inet6 fe80::216:3eff:fe81:27b9/64 scope link
the detail of my instance
incus config show --expanded tes
  image.architecture: amd64
  image.description: Ubuntu jammy amd64 (20240704_07:42)
  image.os: Ubuntu
  image.release: jammy
  image.serial: "20240704_07:42"
  image.type: squashfs
  image.variant: default
  volatile.base_image: 0b77ff338d78acd083690378108c1c4d5f7e9deeb041319ec4c034e472b8f3f3
  volatile.cloud-init.instance-id: 0f1e5254-27f5-4b38-8636-8234fae97ab1
  volatile.eth0.host_name: veth3794a136
  volatile.eth0.hwaddr: 00:16:3e:81:27:b9
  volatile.idmap.base: "0"
  volatile.uuid: 31f9d731-e025-4a42-9ffe-ab72cea28c66
  volatile.uuid.generation: 31f9d731-e025-4a42-9ffe-ab72cea28c66
    network: incusbr2
    pool: default
I restart the incus, reinstall incus, but this never work :confused:
thanks !!!
The most common case is that there is some other service running on the server, and this other service is using port 53 on network device incusbr2.
Use
sudo lsof -nP -iTCP -sTCP:LISTEN
The output should say
COMMAND     PID            USER   FD   TYPE  DEVICE SIZE/OFF NODE NAME
dnsmasq    4037           incus    9u  IPv4   53405      0t0  TCP 10.161.53.1:53 (LISTEN)
That or a firewall conflict, most commonly happening when you also have Docker on the system.
