Incus copy fails with 'Invalid option for volume "test" option "volatile.uuid"'
when I try to copy any existing incus instance (which were migrated from lxd), I get this error:
# incus copy deb11 test
Error: Create instance from copy: Invalid option for volume "test" option "volatile.uuid"
The error even persists when I unset volatile.uuid before trying to copy.
This is the config of the instance, but the error appears for all of my instances when trying to copy:
# incus config show deb11
  image.architecture: amd64
  image.description: Debian bullseye amd64 (20210305_05:24)
  image.os: Debian
  image.release: bullseye
  image.serial: "20210305_05:24"
  image.type: squashfs
  image.variant: default
  security.idmap.isolated: "true"
  volatile.base_image: 540663f718988460e1a2a25a7836a6bd4f75bcaf2e9643925322eee686d5412b
  volatile.eth0.hwaddr: 00:16:3e:3c:64:cc
  volatile.idmap.base: "1327680"
  volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1327680,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1327680,"Nsid":0,"Maprange":65536}]'
  volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1327680,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1327680,"Nsid":0,"Maprange":65536}]'
  volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":1327680,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1327680,"Nsid":0,"Maprange":65536}]'
  volatile.uuid: b429e39a-c26e-4d77-bd4f-90e9c9b90ef0
  volatile.uuid.generation: b429e39a-c26e-4d77-bd4f-90e9c9b90ef0
devices: {}
Incus version is 6.0.0-1~bpo12+1
There is no such thing as volatile.uuid on volume in Incus so that’s probably the problem.
You could wipe any such key with:
incus admin sql global "DELETE FROM storage_volumes_config WHERE key='volatile.uuid'"
That did it! Thank you so much!
