Incus disk quota exceeded when trying to create a snapshot
System info
OS: debian 13.1
Incus: 6.0.5
ZFS: zfs-2.3.2-2, zfs-kmod-2.3.2-2
Incus storage driver: zfs
Issue
Incus is unable to create more than ~480 snapshots, it’s probably related to the size of the instance’s configuration file. It seems like there is a 500MB limit in zfs:
$ incus snapshot create test-snapshot-limit
Error: write /var/lib/incus/virtual-machines/test-snapshot-limit/backup.yaml: disk quota exceeded
$ sudo zfs list [storage-pool-name]/virtual-machines/test-snapshot-limit
NAME                                                       USED  AVAIL  REFER  MOUNTPOINT
[storage-pool-name]/virtual-machines/test-snapshot-limit   498M  1.85M  2.22M  legacy
A quick fix is to increase the quota in zfs:
$ sudo zfs set quota=1G [storage-pool-name]/virtual-machines/test-snapshot-limit
My question is how do I increase this quota by default for new instances ?
How to reproduce
Prerequisite: incus on debian 13 with a zfs pool as default storage
Run this script:
#!/bin/bash
incus launch images:debian/13/cloud test-snapshot-limit < test-config.yml --vm
while [ $? == 0 ]; do
done;
You will have to provide a big configuration file to quickly reach the limit, the one I used includes a long dummy cloud-init config found in the official documentation of cloud-init. Be patient, it took about 15 min to reach the snapshot limit on my computer.
Here is test-config.yml (a lot of dummy data to have a big config file):
test-config.yml
  cloud-init.user-data: |
    #cloud-config
    # apt_pipelining (configure Acquire::http::Pipeline-Depth)
    # Default: disables HTTP pipelining. Certain web servers, such
    # as S3 do not pipeline properly (LP: #948461).
    # Valid options:
    #   False/default: Disables pipelining for APT
    #   None/Unchanged: Use OS default
    #   Number: Set pipelining to some number (not recommended)
    apt_pipelining: False
    # Install additional packages on first boot
    # Default: none
    # if packages are specified, then package_update will be set to true
    packages: ['pastebinit']
    apt:
      # The apt config consists of two major "areas".
      # On one hand there is the global configuration for the apt feature.
      # On one hand (down in this file) there is the source dictionary which allows
      # to define various entries to be considered by apt.
      # Section 1: global apt configuration
      # The following examples number the top keys to ease identification in
      # discussions.
      # 1.1 preserve_sources_list
      # Preserves the existing /etc/apt/sources.list
      # Default: false - do overwrite sources_list. If set to true then any
      # "mirrors" configuration will have no effect.
      # Set to true to avoid affecting sources.list. In that case only
      # "extra" source specifications will be written into
      # /etc/apt/sources.list.d/*
      preserve_sources_list: true
      # 1.2 disable_suites
      # This is an empty list by default, so nothing is disabled.
      # If given, those suites are removed from sources.list after all other
      # modifications have been made.
      # Suites are even disabled if no other modification was made,
      # but not if is preserve_sources_list is active.
      # There is a special alias "$RELEASE" as in the sources that will be replace
      # by the matching release.
      # To ease configuration and improve readability the following common ubuntu
      # suites will be automatically mapped to their full definition.
      # updates   => $RELEASE-updates
      # backports => $RELEASE-backports
      # security  => $RELEASE-security
      # proposed  => $RELEASE-proposed
      # release   => $RELEASE
      # There is no harm in specifying a suite to be disabled that is not found in
      # the source.list file (just a no-op then)
      # Note: Lines don't get deleted, but disabled by being converted to a comment.
      # The following example disables all usual defaults except $RELEASE-security.
      # On top it disables a custom suite called "mysuite"
      disable_suites: [$RELEASE-updates, backports, $RELEASE, mysuite]
      # 1.3 primary/security archives
      # Default: none - instead it is auto select based on instance-data
      # so if neither "uri" nor "search", nor "search_dns" is set (the default)
      # then use the mirror provided by the DataSource found.
      # In EC2, that means using <region>.ec2.archive.ubuntu.com
      # define a custom (e.g. localized) mirror that will be used in sources.list
      # and any custom sources entries for deb / deb-src lines.
      # One can set primary and security mirror to different uri's
      # the child elements to the keys primary and secondary are equivalent
      primary:
        # arches is list of architectures the following config applies to
        # the special keyword "default" applies to any architecture not explicitly
        # listed.
        - arches: [amd64, i386, default]
          # uri is just defining the target as-is
          uri: http://us.archive.ubuntu.com/ubuntu
          # via search one can define lists that are tried one by one.
          # The first with a working DNS resolution (or if it is an IP) will be
          # picked. That way one can keep one configuration for multiple
          # subenvironments that select the working one.
          search:
            - http://cool.but-sometimes-unreachable.com/ubuntu
            - http://us.archive.ubuntu.com/ubuntu
          # if no mirror is provided by uri or search but 'search_dns' is
          # true, then search for dns names '<distro>-mirror' in each of
          # - fqdn of this host per meta-data
          # - localdomain
          # - no domain (which would search domains listed in /etc/resolv.conf)
          # If there is a dns entry for <distro>-mirror, then it is assumed that
          # there is a distro mirror at http://<distro>-mirror.<domain>/<distro>
          # That gives the cloud provider the opportunity to set mirrors of a distro
          # up and expose them only by creating dns entries.
          # if none of that is found, then the default distro mirror is used
          search_dns: true
          # If multiple of a category are given
          #   1. uri
          #   2. search
          #   3. search_dns
          # the first defining a valid mirror wins (in the order as defined here,
          # not the order as listed in the config).
          # Additionally, if the repository requires a custom signing key, it can be
          # specified via the same fields as for custom sources:
          #   'keyid': providing a key to import via shortid or fingerprint
          #   'key': providing a raw PGP key
          #   'keyserver': specify an alternate keyserver to pull keys from that
          #                were specified by keyid
        - arches: [s390x, arm64]
          # as above, allowing to have one config for different per arch mirrors
      # security is optional, if not defined it is set to the same value as primary
      security:
        - uri: http://security.ubuntu.com/ubuntu
          arches: [default]
      # If search_dns is set for security the searched pattern is:
      #   <distro>-security-mirror
      # if no mirrors are specified at all, or all lookups fail it will try
      # to get them from the cloud datasource and if those neither provide one fall
      # back to:
      #   primary: http://archive.ubuntu.com/ubuntu
      #   security: http://security.ubuntu.com/ubuntu
      # 1.4 sources_list
      # Provide a custom template for rendering sources.list
      # without one provided cloud-init uses builtin templates for
      # ubuntu and debian.
      # Within these sources.list templates you can use the following replacement
      # variables (all have sane Ubuntu defaults, but mirrors can be overwritten
      # as needed (see above)):
      # => $RELEASE, $MIRROR, $PRIMARY, $SECURITY
      sources_list: | # written by cloud-init custom template
        deb $MIRROR $RELEASE main restricted
        deb-src $MIRROR $RELEASE main restricted
        deb $PRIMARY $RELEASE universe restricted
        deb $SECURITY $RELEASE-security multiverse
      # 1.5 conf
      # Any apt config string that will be made available to apt
      # see the APT.CONF(5) man page for details what can be specified
      conf: | # APT config
        APT {
          Get {
            Assume-Yes "true";
            Fix-Broken "true";
      # 1.6 (http_|ftp_|https_)proxy
      # Proxies are the most common apt.conf option, so that for simplified use
      # there is a shortcut for those. Those get automatically translated into the
      # correct Acquire::*::Proxy statements.
      # note: proxy actually being a short synonym to http_proxy
      proxy: http://[[user][:pass]@]host[:port]/
      http_proxy: http://[[user][:pass]@]host[:port]/
      ftp_proxy: ftp://[[user][:pass]@]host[:port]/
      https_proxy: https://[[user][:pass]@]host[:port]/
      # 1.7 add_apt_repo_match
      # 'source' entries in apt-sources that match this python regex
      # expression will be passed to add-apt-repository
      # The following example is also the builtin default if nothing is specified
      add_apt_repo_match: '^[\w-]+:\w'
      # Section 2: source list entries
      # This is a dictionary (unlike most block/net which are lists)
      # The key of each source entry is the filename and will be prepended by
      # /etc/apt/sources.list.d/ if it doesn't start with a '/'.
      # If it doesn't end with .list it will be appended so that apt picks up its
      # configuration.
      # Whenever there is no content to be written into such a file, the key is
      # not used as filename - yet it can still be used as index for merging
      # configuration.
      # The values inside the entries consist of the following optional entries:
      #   'source': a sources.list entry (some variable replacements apply)
      # This allows merging between multiple input files than a list like:
      # cloud-config1
      # sources:
      #   s1: {'key': 'key1', 'source': 'source1'}
      # cloud-config2
      # sources:
      #   s2: {'key': 'key2'}
      #   s1: {'keyserver': 'foo'}
      # This would be merged to
      # sources:
      #   s1:
      #     keyserver: foo
      #     key: key1
      #     source: source1
      #   s2:
      #     key: key2
      # The following examples number the subfeatures per sources entry to ease
      # identification in discussions.
      sources:
        curtin-dev-ppa.list:
          # 2.1 source
          # Creates a file in /etc/apt/sources.list.d/ for the sources list entry
          # based on the key: "/etc/apt/sources.list.d/curtin-dev-ppa.list"
          source: "deb http://ppa.launchpad.net/curtin-dev/test-archive/ubuntu bionic main"
          # 2.2 keyid
          # Importing a gpg key for a given key id. Used keyserver defaults to
          # keyserver.ubuntu.com
          keyid: F430BBA5 # GPG key ID published on a key server
        ignored1:
          # 2.3 PPA shortcut
          # Setup correct apt sources.list line and Auto-Import the signing key
          # from LP
          # See https://help.launchpad.net/Packaging/PPA for more information
          # this requires 'add-apt-repository'. This will create a file in
          # /etc/apt/sources.list.d automatically, therefore the key here is
          # ignored as filename in those cases.
          source: "ppa:curtin-dev/test-archive"    # Quote the string
        my-repo2.list:
          # 2.4 replacement variables
          # sources can use $MIRROR, $PRIMARY, $SECURITY, $RELEASE and $KEY_FILE
          # replacement variables.
          # They will be replaced with the default or specified mirrors and the
          # running release.
          # The entry below would be possibly turned into:
          #   source: deb http://archive.ubuntu.com/ubuntu bionic multiverse
          source: deb [signed-by=$KEY_FILE] $MIRROR $RELEASE multiverse
          keyid: F430BBA5
        my-repo3.list:
          # this would have the same end effect as 'ppa:curtin-dev/test-archive'
          keyid: F430BBA5 # GPG key ID published on the key server
          filename: curtin-dev-ppa.list
        ignored2:
          # 2.5 key only
          # this would only import the key without adding a ppa or other source spec
          # since this doesn't generate a source.list file the filename key is ignored
        ignored3:
          # 2.6 key id alternatives
          # Keyid's can also be specified via their long fingerprints
          keyid: B59D 5F15 97A5 04B7 E230  6DCA 0620 BBCF 0368 3F77
        ignored4:
          # 2.7 alternative keyservers
          # One can also specify alternative keyservers to fetch keys from.
          keyserver: pgp.mit.edu
        ignored5:
          # 2.8 signed-by
          # One can specify [signed-by=$KEY_FILE] in the source definition, which
          # will make the key be installed in the directory /etc/cloud-init.gpg.d/
          # and the $KEY_FILE replacement variable will be replaced with the path
          # to the specified key. If $KEY_FILE is used, but no key is specified,
          # apt update will (rightfully) fail due to an invalid value.
        my-repo4.list:
          # 2.9 raw key
          # The apt signing key can also be specified by providing a pgp public key
          # block. Providing the PGP key this way is the most robust method for
          # specifying a key, as it removes dependency on a remote key server.
          # As with keyid's this can be specified with or without some actual source
          # content.
          key: | # The value needs to start with -----BEGIN PGP PUBLIC KEY BLOCK-----
            Version: SKS 1.0.10
            mI0ESpA3UQEEALdZKVIMq0j6qWAXAyxSlF63SvPVIgxHPb9Nk0DZUixn+akqytxG4zKCONz6
            qLjoBBfHnynyVLfT4ihg9an1PqxRnTO+JKQxl8NgKGz6Pon569GtAOdWNKw15XKinJTDLjnj
            9y96ljJqRcpV9t/WsIcdJPcKFR5voHTEoABE2aEXABEBAAG0GUxhdW5jaHBhZCBQUEEgZm9y
            IEFsZXN0aWOItgQTAQIAIAUCSpA3UQIbAwYLCQgHAwIEFQIIAwQWAgMBAh4BAheAAAoJEA7H
            5Qi+CcVxWZ8D/1MyYvfj3FJPZUm2Yo1zZsQ657vHI9+pPouqflWOayRR9jbiyUFIn0VdQBrP
            t0FwvnOFArUovUWoKAEdqR8hPy3M3APUZjl5K4cMZR/xaMQeQRZ5CHpS4DBKURKAHC0ltS5o
            uBJKQOZm5iltJp15cgyIkBkGe8Mx18VFyVglAZey
            =Y2oI
            -----END PGP PUBLIC KEY BLOCK-----
    pool: [storage-pool-name]
Thanks in advance for your help !
Hmm, it’s not normal for a VM config volume to be that large.
You can alter the size in Incus by setting the size.state property on the root disk, but it would be good to mount that dataset somewhere on the host and see what’s using so much space inside it.
Thanks a lot for your answer. After looking at the zfs properties, it seems like most of this space is used by the snapshots.
$ zfs get all safestorage/virtual-machines/test-snapshot-limit
safestorage/virtual-machines/test-snapshot-limit  used                  499M        -
safestorage/virtual-machines/test-snapshot-limit  available             1.09M        -
safestorage/virtual-machines/test-snapshot-limit  referenced            2.23M
safestorage/virtual-machines/test-snapshot-limit  usedbysnapshots       497M        -
safestorage/virtual-machines/test-snapshot-limit  usedbydataset         2.17M
Is it the intended behavior that size.state includes the space taken by snapshots ?
