Gonna try a different approach.
I have a IncusOS using a 1tb nvme. The local zfs pool shows 2.8mb of 891gb being used.
Lets say I want to create several FreeBSD vm’s that are 50gb each.
First. Is that possible?
If yes, what steps would I need to take to achieve that? In other words, do I create a storage pool
or volume or and add the storage volume to a profile, then create my instance using that profile?
I want to get the concepts in my mind before creating the instances.
Launching v1
Error: Failed instance creation: The image used by this instance is incompatible with secureboot. Please set security.secureboot=false on the instance
So you need to disable secure boot for this image:
Thanks for taking the time. It looks like most of the veterans are using the command line
to interact with IncusOS. My first step will be to get that out of the way. So far I’ve been using the
UI and earlier created FreeBSD vm’s. The UI indicated the vm didn’t support secure boot. I was able to locate that setting, and ended up with working FreeBSD instances.
For the second time around, I want to improve my skills.So the profiles and projects, storage
are on my list.
I found a couple good Incus profile tutorials on the web, I’m going to do some reading/testing
then return here.
