I’m aware of dnsmasq and conflicting mac addresses but cant quite figure out why on a fresh container without any config change the IP is fixed but once I change config it then no longer keeps the same IP after reboot etc, volatile mac stays the same until config change then always changes. Any pointers on how to resolve this. I use the LXD api to make config changes. This didnt happen before v3
root@...:~# lxc config show isOK
image.architecture: amd64
image.description: ubuntu 18.04 LTS amd64 (release) (20200129.1)
image.label: release
image.os: ubuntu
image.release: bionic
image.serial: "20200129.1"
image.type: squashfs
image.version: "18.04"
volatile.base_image: 9e7158fc0683d41f7f692ce8b17598716d7eee925c6a593432df59488bf4131f
volatile.eth0.host_name: vetha24eb48e
volatile.eth0.hwaddr: 00:16:3e:72:a9:0f
volatile.idmap.base: "0"
devices: {}
root@...:~# lxc config show alwaysChanges
boot.autostart: "1"
image.os: ubuntu
limits.cpu: "1"
limits.cpu.allowance: 100%
limits.cpu.priority: "10"
limits.disk.priority: "10"
limits.memory: 1024MB
limits.memory.enforce: hard
limits.memory.swap: "0"
limits.memory.swap.priority: "10"
limits.network.priority: "10"
limits.processes: "2000"
user.sshkeys: "10"
volatile.eth0.host_name: veth0e061d91
volatile.eth0.hwaddr: 00:16:3e:99:f3:f9
ssh alwaysChanges:
bind: host
connect: tcp:10.67.1.147:22
listen: tcp:snip:2200
type: proxy
root@...:~#
now once config is changed, on isOK, then no longer keeps same IP ![]()
image.os: ubuntu
limits.cpu: "1"
limits.cpu.allowance: 50%
limits.cpu.priority: "5"
limits.disk.priority: "5"
limits.memory.enforce: soft
limits.memory.swap.priority: "5"
limits.network.priority: "5"
limits.processes: "2500"
volatile.eth0.host_name: veth1bf660d1
volatile.eth0.hwaddr: 00:16:3e:00:54:fc
devices: {}
