One-line reproducer (incus 7.0.1)
nsrc@host1:~$ time incus launch images:ubuntu/26.04/cloud --vm testvm --console
Launching testvm
To detach from the console, press: <ctrl>+a q
BdsDxe: loading Boot0002 "UEFI QEMU QEMU HARDDISK " from PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/Scsi(0x0,0x1)
BdsDxe: starting Boot0002 "UEFI QEMU QEMU HARDDISK " from PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/Scsi(0x0,0x1)
[ 2.244817] systemd[1]: Failed to preset all unit: Unit /etc/systemd/system/ua-auto-attach.service is masked
[ 2.248110] systemd[1]: Failed to preset all unit: Unit chronyd.service is an unresolvable alias
[ 2.248651] systemd[1]: Failed to preset all unit: Unit /run/systemd/generator/boot-efi.mount is transient or generated
[ 2.249282] systemd[1]: Failed to preset all unit: Unit /run/systemd/generator/-.mount is transient or generated
[ 2.249890] systemd[1]: Failed to preset all unit: Unit /usr/lib/systemd/system/hwclock.service is masked
[ 2.250448] systemd[1]: Failed to preset all unit: Unit /usr/lib/systemd/system/cryptdisks.service is masked
[ 2.251025] systemd[1]: Failed to preset all unit: Unit /usr/lib/systemd/system/x11-common.service is masked
[ 2.251589] systemd[1]: Failed to preset all unit: Unit /usr/lib/systemd/system/cryptdisks-early.service is masked
[ 2.252188] systemd[1]: Failed to preset all unit: Unit /usr/lib/systemd/system/sudo.service is masked
[ 2.252727] systemd[1]: Failed to preset all unit: Unit /run/systemd/generator.late/netplan-ovs-cleanup.service is transient or generated
[ 2.253431] systemd[1]: Failed to preset all unit /etc/systemd/system/ctrl-alt-del.target: Read-only file system
[ 2.254011] systemd[1]: Failed to preset all unit /etc/systemd/system/dracut-pre-udev.service: Read-only file system
[ 2.254594] systemd[1]: Failed to preset all unit /etc/systemd/system/multi-user.target.wants/remote-veritysetup.target: Read-only file system
[ 2.255311] systemd[1]: Failed to preset all unit /etc/systemd/system/dracut-cmdline.service: Read-only file system
[ 2.255910] systemd[1]: Failed to preset all unit /etc/systemd/system/sysinit.target.wants/systemd-sysext.service: Read-only file system
[ 2.256627] systemd[1]: Failed to preset all unit /etc/systemd/system/sockets.target.wants/systemd-sysext.socket: Read-only file system
[ 2.257297] systemd[1]: Failed to preset all unit /etc/systemd/system/sysinit.target.wants/systemd-pcrlock-machine-id.service: Read-only file system
[ 2.258111] systemd[1]: Failed to preset all unit /etc/systemd/system/sysinit.target.wants/systemd-pcrlock-file-system.service: Read-only file system
[ 2.258921] systemd[1]: Failed to preset all unit: Unit /etc/systemd/system/factory-reset.target.wants/systemd-tpm2-clear.service does not exist
[ 2.259658] systemd[1]: Failed to preset all unit /etc/systemd/system/dracut-pre-trigger.service: Read-only file system
[ 2.260268] systemd[1]: Failed to preset all unit /etc/systemd/system/sysinit.target.wants/systemd-pcrlock-firmware-code.service: Read-only file system
[ 2.261026] systemd[1]: Failed to preset all unit /etc/systemd/system/dracut-pre-pivot.service: Read-only file system
[ 2.261614] systemd[1]: Failed to preset all unit /etc/systemd/system/sysinit.target.wants/systemd-pcrlock-make-policy.service: Read-only file system
[ 2.262375] systemd[1]: Failed to preset all unit /etc/systemd/system/sysinit.target.wants/systemd-udev-load-credentials.service: Read-only file system
[ 2.263137] systemd[1]: Failed to preset all unit /etc/systemd/system/dracut-pre-mount.service: Read-only file system
[ 2.263730] systemd[1]: Failed to preset all unit /etc/systemd/system/dracut-shutdown-onfailure.service: Read-only file system
[ 2.264380] systemd[1]: Failed to preset all unit /etc/systemd/system/sysinit.target.wants/systemd-pcrlock-firmware-config.service: Read-only file system
[ 2.265144] systemd[1]: Failed to preset all unit /etc/systemd/system/sysinit.target.wants/systemd-pcrlock-secureboot-policy.service: Read-only file system
[ 2.265922] systemd[1]: Failed to preset all unit /etc/systemd/system/sockets.target.wants/systemd-journald-audit.socket: Read-only file system
[ 2.266637] systemd[1]: Failed to preset all unit: Unit /etc/systemd/system/systemd-journald.service.wants/systemd-journald-audit.socket does not exist
[ 2.267407] systemd[1]: Failed to preset all unit /etc/systemd/system/multi-user.target.wants/remote-cryptsetup.target: Read-only file system
[ 2.268115] systemd[1]: Failed to preset all unit /etc/systemd/system/dracut-shutdown.service: Read-only file system
[ 2.268700] systemd[1]: Failed to preset all unit /etc/systemd/system/dracut-mount.service: Read-only file system
[ 2.269274] systemd[1]: Failed to preset all unit /etc/systemd/system/sockets.target.wants/systemd-pcrextend.socket: Read-only file system
[ 2.270026] systemd[1]: Failed to preset all unit /etc/systemd/system/sockets.target.wants/systemd-factory-reset.socket: Read-only file system
[ 2.270754] systemd[1]: Failed to preset all unit /etc/systemd/system/sysinit.target.wants/systemd-pcrlock-secureboot-authority.service: Read-only file system
[ 2.271574] systemd[1]: Failed to preset all unit /etc/systemd/system/sysinit.target.wants/systemd-confext.service: Read-only file system
[ 2.272289] systemd[1]: Failed to preset all unit /etc/systemd/system/multi-user.target.wants/remote-integritysetup.target: Read-only file system
[ 2.273058] systemd[1]: Failed to preset all unit /etc/systemd/system/dracut-initqueue.service: Read-only file system
[ 3.168307] cloud-init[384]: Cloud-init v. 26.1-0ubuntu3~26.04.1 running 'init-local' at Wed, 26 Aug 2026 15:49:56 +0000. Up 3.14 seconds.
[ 3.180040] cloud-init[384]: 2026-08-26 15:49:57,007 - DataSourceLXD.py[WARNING]: /dev/lxd/sock does not exist.
[ 4.124334] cloud-init[384]: Cloud-init v. 26.1-0ubuntu3~26.04.1 running 'init' at Wed, 26 Aug 2026 15:49:57 +0000. Up 4.10 seconds.
[ 4.262078] cloud-init[384]: 2026-08-26 15:49:58,089 - ubuntu.py[ERROR]: Failed to wait for network: Unexpected error while running command.
[ 4.323605] cloud-init[384]: Command: ['systemctl', 'start', 'systemd-networkd-wait-online.service']
[ 4.327079] cloud-init[384]: Exit code: 1
[ 4.327430] cloud-init[384]: Reason: -
[ 4.327716] cloud-init[384]: Stdout:
[ 4.327982] cloud-init[384]: Stderr: Job for systemd-networkd-wait-online.service canceled.
[ 4.336032] cloud-init[384]: ci-info: +++++++++++++++++++++++++++Net device info++++++++++++++++++++++++++++
[ 4.346093] cloud-init[384]: ci-info: +--------+-------+-----------+-----------+-------+-------------------+
[ 4.346794] cloud-init[384]: ci-info: | Device | Up | Address | Mask | Scope | Hw-Address |
[ 4.357111] cloud-init[384]: ci-info: +--------+-------+-----------+-----------+-------+-------------------+
[ 4.360845] cloud-init[384]: ci-info: | enp5s0 | False | . | . | . | 10:66:6a:b7:da:24 |
[ 4.366160] cloud-init[384]: ci-info: | lo | True | 127.0.0.1 | 255.0.0.0 | host | . |
[ 4.369838] cloud-init[384]: ci-info: | lo | True | ::1/128 | . | host | . |
[ 4.373056] cloud-init[384]: ci-info: +--------+-------+-----------+-----------+-------+-------------------+
[ 4.377161] cloud-init[384]: ci-info: +++++++++++++++++++Route IPv6 info+++++++++++++++++++
[ 4.381600] cloud-init[384]: ci-info: +-------+-------------+---------+-----------+-------+
[ 4.383093] cloud-init[384]: ci-info: | Route | Destination | Gateway | Interface | Flags |
[ 4.386158] cloud-init[384]: ci-info: +-------+-------------+---------+-----------+-------+
[ 4.389068] cloud-init[384]: ci-info: +-------+-------------+---------+-----------+-------+
[ 4.445501] cloud-init[384]: Received signal 15 resulting in exit. Cause:
[ 4.446053] cloud-init[384]: Filename: /usr/lib/python3.14/selectors.py
Function: select
Line number: 398
Filename: /usr/lib/python3.14/subprocess.py
Function: _communicate
Line number: 2153
Function: communicate
Line number: 1221
[ 4.450067] cloud-init[384]: Function: select
[ 4.453963] cloud-init[384]: Line number: 398
[ 4.455787] cloud-init[384]: Filename: /usr/lib/python3.14/subprocess.py
[ 4.456750] cloud-init[384]: Function: _communicate
[ 4.457979] cloud-init[384]: Line number: 2153
[ 4.460670] cloud-init[384]: Filename: /usr/lib/python3.14/subprocess.py
[ 4.462346] cloud-init[384]: Function: communicate
[ 4.464047] cloud-init[384]: Line number: 1221
[ 4.465077] cloud-init[384]: Traceback (most recent call last):
[ 4.466175] cloud-init[384]: File "/usr/bin/cloud-init", line 9, in <module>
[ 4.469036] cloud-init[384]: sys.exit(main.main())
[ 4.469450] cloud-init[384]: ~~~~~~~~~^^
[ 4.470885] cloud-init[384]: File "/usr/lib/python3/dist-packages/cloudinit/cmd/main.py", line 1309, in main
[ 4.473343] cloud-init[384]: return all_stages(parser)
[ 4.474036] cloud-init[384]: File "/usr/lib/python3/dist-packages/cloudinit/cmd/main.py", line 1331, in all_stages
[ 4.476790] cloud-init[384]: with sync("network"):
[ 4.477318] cloud-init[384]: ~~~~^^^^^^^^^^^
[ 4.479053] cloud-init[384]: File "/usr/lib/python3/dist-packages/cloudinit/socket.py", line 161, in __exit__
[ 4.479791] cloud-init[384]: sock.sendall(
[ 4.481034] cloud-init[384]: ~~~~~~~~~~~~^
[ 4.481422] cloud-init[384]: f"echo '{message}'; exit {self.systemd_exit_code};".encode()
[ 4.483038] cloud-init[384]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
[ 4.483673] cloud-init[384]: )
[ 4.485036] cloud-init[384]: ^
[ 4.485323] cloud-init[384]: BrokenPipeError: [Errno 32] Broken pipe
[ 4.652023] reboot: Restarting system
real 0m12.605s
user 0m0.080s
sys 0m0.046s
The VM reboots and comes up successfully on the second attempt. This looks a bit disconcerting though.
ubuntu/26.04 does not have this issue. This suggests it’s cloud-init specific.
Aside: I also tried freebsd/15.1/cloud. It also reboots, but I think this is unrelated, as it’s due to auto-applying updates. In /var/log/messages I see:
Aug 26 15:57:41 testvm3 pkg[1789]: [80/80] Upgrading FreeBSD-zoneinfo from 15.1 to 15.1p2...
Aug 26 15:57:41 testvm3 pkg[1789]: [80/80] Extracting FreeBSD-zoneinfo-15.1p2: .......... done
Aug 26 15:57:41 testvm3 pkg[1800]: FreeBSD-zoneinfo upgraded: 15.1 -> 15.1p2
Aug 26 15:57:41 testvm3 pkg[1789]: ==> Running trigger: mandoc.ucl
Aug 26 15:57:41 testvm3 pkg[1789]: Generating apropos(1) database for /usr/share/man...
Aug 26 15:57:42 testvm3 pkg[1789]: Generating apropos(1) database for /usr/share/openssl/man...
Aug 26 15:57:43 testvm3 pkg[1789]: Requesting reboot after installing updates.
Aug 26 15:57:43 testvm3 syslogd: exiting on signal 15
Aug 26 15:57:59 testvm3 syslogd: kernel boot file is /boot/kernel/kernel
Aug 26 15:57:59 testvm3 kernel: ---<<BOOT>>---
Aug 26 15:57:59 testvm3 kernel: Copyright (c) 1992-2025 The FreeBSD Project.
Aug 26 15:57:59 testvm3 kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
However, I can’t find any trace of cloud-init on the system:
root@testvm3:~ # find / -iname '*cloud*'
root@testvm3:~ #
This seems strange for a /cloud variant.
