Hello container folks,
I have had good success with copying containers in between different hosts, but recently ran into an issue. Both hosts run LXD version 3.0.3 with a ZFS storage backend.
despens@my-host:~$ lxc copy other-host:my-container my-container
Error: Failed container creation:
- https://1.2.3.4:8443: Error transferring container data: Unable to connect to: 1.2.3.4:8443
- https://1.2.3.4:8443: Error transferring container data: Create LXC container: Invalid devices: Detect root disk device: No root device could be found
The first error, “Unable to connect” is definitely incorrect, as I am able to manage conainers on that host remotely and had several successful copy operations before.
I do not understand what the second error means.
The container to be copied was created in a standard way, starting out with a default image. It features 5 snapshots.
despens@my-host:~$ lxc info other-host:my-container
Remote: https://1.2.3.4:8443
Created: 2019/01/13 19:25 UTC
Status: Running
Type: persistent
Profiles: default
Pid: 31045
Ips:
eth0: inet x.x.x.x veth78A0MA
eth0: inet6 x::x:x:x:x veth78A0MA
lo: inet 127.0.0.1
lo: inet6 ::1
Resources:
Processes: 45
Disk usage:
root: 5.68GB
CPU usage:
CPU usage (in seconds): 16
Memory usage:
Memory (current): 165.35MB
Memory (peak): 166.22MB
Network usage:
Bytes received: 199.20kB
Bytes sent: 1.28MB
Packets received: 1454
Packets sent: 1016
lo:
Bytes received: 0B
Bytes sent: 0B
Packets received: 0
Packets sent: 0
Snapshots:
snap-1
snap-2
snap-3
snap-4
snap-5
Any idea what’s the case here?
