I implemented a throttling mechism based on thermocouple temperature readings to reduce the cpu usage of all running containers by using cpu_alllowance. My development box was an old single CPU motherboard and it worked perfectly. I’m using ubuntu server 20.04 LTE for all my installs.
I implemented a monitoring script for the thermocouples which feeds into collectd then configured collectd with a warning threshold and a failure threshold. Worked perfectly including removing the cpu_allowance once the CPU went outside of the abnormal temps…
However now that I’m testing on deployment machines… 2xXeon E5 V3 chips on a Supermicro X10DRi motherboard. I find that the CPU allowance has no effect what so ever.
So If I set a limits.cpu_allowance of “10ms/100ms” I would expect the target container to get 10ms per 100ms of CPU on a single CPU. Not use all of the CPU’s its configured for a 100%?
How is the cpu_allow implemented and why would it not work?, Is it todo with kernel support CPU chipset or something else?
What can I do to find out or fix this issue?
