Hi, I’m trying to test live migration but im having hard time doing it, I tested different versions and configurations with no success, Migration between two hosts is failing with this message:
$ lxc move test1 ibra3:
error: Failed container creation:
- https://10.40.128.12:8443: Error transferring container data: Failed to run: /usr/bin/lxd forkmigrate test1 /var/lib/lxd/containers /var/log/lxd/test1/lxc.conf /tmp/lxd_restore_820736425 true:
container image is ubuntu 16.04
host is ubuntu 17.04 with kernel:
Linux ibratest-2 4.13.0-21-generic #24-Ubuntu SMP Mon Dec 18 17:29:16 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
on destination host I got this log:
$ cat /var/log/lxd/lxd.log
ephemeral=false lvl=info msg="Creating container" name=test2 t=2018-01-08T13:23:54+0000
ephemeral=false lvl=info msg="Created container" name=test2 t=2018-01-08T13:23:54+0000
lvl=warn msg="Unable to update backup.yaml at this time." name=test2 t=2018-01-08T13:23:54+0000
ephemeral=false lvl=info msg="Creating container" name=test2/s3 t=2018-01-08T13:23:55+0000
ephemeral=false lvl=info msg="Created container" name=test2/s3 t=2018-01-08T13:23:55+0000
ephemeral=false lvl=info msg="Creating container" name=test2/s4 t=2018-01-08T13:24:00+0000
ephemeral=false lvl=info msg="Created container" name=test2/s4 t=2018-01-08T13:24:00+0000
actionscript=false created=2018-01-08T13:23:54+0000 ephemeral=false lvl=info msg="Migrating container" name=test2 statedir=/tmp/lxd_restore_982407591 stop=false t=2018-01-08T13:24:04+0000 used=1970-01-01T00:00:00+0000
action=stop created=2018-01-08T13:23:54+0000 ephemeral=false lvl=info msg="Container initiated stop" name=test2 stateful=false t=2018-01-08T13:24:05+0000 used=2018-01-08T13:24:04+0000
action=stop created=2018-01-08T13:23:54+0000 ephemeral=false lvl=info msg="Container initiated stop" name=test2 stateful=false t=2018-01-08T13:24:06+0000 used=2018-01-08T13:24:04+0000
err="remove /sys/kernel/security/apparmor/policy/namespaces/lxd-test2_<var-lib-lxd>: no such file or directory" lvl=eror msg="error removing apparmor namespace" ns=/sys/kernel/security/apparmor/policy/namespaces/lxd-test2_<var-lib-lxd> t=2018-01-08T13:24:06+0000
err="open /tmp/lxd_restore_982407591/restore.log: no such file or directory" lvl=eror msg="Error collecting checkpoint log file" t=2018-01-08T13:24:06+0000
err="Failed to run: /usr/bin/lxd forkmigrate test2 /var/lib/lxd/containers /var/log/lxd/test2/lxc.conf /tmp/lxd_restore_982407591 true: " lvl=eror msg="Error during migration sink" t=2018-01-08T13:24:06+0000
created=2018-01-08T13:23:54+0000 ephemeral=false lvl=info msg="Deleting container" name=test2 t=2018-01-08T13:24:06+0000 used=1970-01-01T00:00:00+0000
created=2018-01-08T13:23:55+0000 ephemeral=false lvl=info msg="Deleting container" name=test2/s3 t=2018-01-08T13:24:06+0000 used=1970-01-01T00:00:00+0000
created=2018-01-08T13:23:55+0000 ephemeral=false lvl=info msg="Deleted container" name=test2/s3 t=2018-01-08T13:24:06+0000 used=1970-01-01T00:00:00+0000
created=2018-01-08T13:24:00+0000 ephemeral=false lvl=info msg="Deleting container" name=test2/s4 t=2018-01-08T13:24:06+0000 used=1970-01-01T00:00:00+0000
created=2018-01-08T13:24:00+0000 ephemeral=false lvl=info msg="Deleted container" name=test2/s4 t=2018-01-08T13:24:06+0000 used=1970-01-01T00:00:00+0000
action=R err="Failed to run: apparmor_parser -RWL /var/lib/lxd/security/apparmor/cache /var/lib/lxd/security/apparmor/profiles/lxd-test2: apparmor_parser: Unable to remove \"lxd-test2_</var/lib/lxd>\". Profile doesn't exist" lvl=eror msg="Running apparmor" output="apparmor_parser: Unable to remove \"lxd-test2_</var/lib/lxd>\". Profile doesn't exist\n" t=2018-01-08T13:24:06+0000
container=test2 err="Failed to run: apparmor_parser -RWL /var/lib/lxd/security/apparmor/cache /var/lib/lxd/security/apparmor/profiles/lxd-test2: apparmor_parser: Unable to remove \"lxd-test2_</var/lib/lxd>\". Profile doesn't exist" lvl=eror msg="Failed to destroy apparmor namespace" t=2018-01-08T13:24:06+0000
created=2018-01-08T13:23:54+0000 ephemeral=false lvl=info msg="Deleted container" name=test2 t=2018-01-08T13:24:06+0000 used=1970-01-01T00:00:00+0000
and
cat /var/log/lxd/test2/lxc.log
lxc 20180108132404.933 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc 20180108132405.144 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc 20180108132405.213 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc 20180108132405.871 ERROR lxc_criu - criu.c:do_restore:978 - criu process exited 1, output:
lxc 20180108132405.871 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc 20180108132405.871 WARN lxc_commands - commands.c:lxc_cmd_rsp_recv:125 - Command get_cgroup failed to receive response: Connection reset by peer.
lxc 20180108132405.878 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/unified//lxc/test2
lxc 20180108132405.885 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/systemd//lxc/test2
lxc 20180108132405.891 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/hugetlb//lxc/test2
lxc 20180108132405.898 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/cpu//lxc/test2
lxc 20180108132405.904 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/rdma//lxc/test2
lxc 20180108132405.911 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/freezer//lxc/test2
lxc 20180108132405.917 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/blkio//lxc/test2
lxc 20180108132405.925 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/devices//lxc/test2
lxc 20180108132405.931 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/net_cls//lxc/test2
lxc 20180108132405.938 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/cpuset//lxc/test2
lxc 20180108132405.945 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/perf_event//lxc/test2
lxc 20180108132405.952 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/pids//lxc/test2
lxc 20180108132405.958 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/memory//lxc/test2
lxc 20180108132405.958 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc 20180108132406.557 ERROR lxc_criu - criu.c:__criu_restore:1284 - restore process died
source and destination instalation are identical;
lxc info
core.https_address: 10.40.128.15:8443
core.trust_password: true
images.auto_update_interval: "0"
api_extensions:
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
api_status: stable
api_version: "1.0"
auth: trusted
public: false
environment:
addresses:
- 10.40.128.15:8443
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
MIIFUzCCAzugAwIBAgC52cS2kFym5/VLWL3S/RWMgvmX5qAJ
W6s5spwdW8LbT4m75iggmGh3dEF0uACHifAhHnbJazavHIgp7F17zy/8DUnytW0T
kcYDIJhOH7ytrM1kWKP22ulnQ9H5ryw=
-----END CERTIFICATE-----
certificate_fingerprint: 4a5b56e3e0f260c86a81106ee7dbd5b92862401bd56cdabd56a50018285ea612
driver: lxc
driver_version: 2.1.1
kernel: Linux
kernel_architecture: x86_64
kernel_version: 4.13.0-21-generic
server: lxd
server_pid: 4072
server_version: "2.18"
storage: zfs
storage_version: 0.6.5.11-1ubuntu3
criu installed from source:
sudo criu --version
Version: 3.7
GitID: v3.7
Any hint?
Many thanks
stgraber
(Stéphane Graber)
January 8, 2018, 6:47pm
2
I’d recommend upgrading to the latest LXD first, just in case this helps:
apt install -t artful-backports lxd lxd-client
Then the best first step is to try just a local stateful snapshot or stateful stop, that tends to isolate things to just CRIU and make it easier to look at logs:
lxc snapshot test1 --stateful
lxc stop test1 --stateful
Either of those will have LXD tell CRIU to dump the container to disk.
Any failure should result in a log file in /var/log/lxd/test1/
Hi Stéphane,
Thank you for answering!
I installed the version from artful-backports, restarted lxd and redid the test, but still having the same error . the stateful snapshot is working the problem is in the restore process
ubuntu@ibratest-2:~$ lxc snapshot test2 s2 --stateful
ubuntu@ibratest-2:~$ lxc stop test2 --stateful
ubuntu@ibratest-2:~$ lxc start test2
error: Failed to run: /usr/bin/lxd forkmigrate test2 /var/lib/lxd/containers /var/log/lxd/test2/lxc.conf /var/lib/lxd/containers/test2/state true:
Try `lxc info --show-log test2` for more info
driver: lxc
kernel: Linux
server: lxd
server_pid: 14000
server_version: "2.21"
storage: zfs
exactly the same error but now in the same host:
Remote: unix://
Created: 2018/01/08 13:17 UTC
Status: Stopped
Type: persistent
Profiles: default
Snapshots:
s2 (taken at 2018/01/09 09:37 UTC) (stateful)
Log:
lxc 20180109093745.309 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc 20180109093745.437 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc 20180109093745.524 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc 20180109093746.488 ERROR lxc_conf - conf.c:run_buffer:438 - Script exited with status 1.
lxc 20180109093746.488 ERROR lxc_start - start.c:lxc_fini:753 - Failed to run lxc.hook.post-stop for container "test2".
lxc 20180109093746.673 ERROR lxc_criu - criu.c:do_restore:978 - criu process exited 1, output:
lxc 20180109093746.675 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc 20180109093746.676 WARN lxc_commands - commands.c:lxc_cmd_rsp_recv:125 - Command get_cgroup failed to receive response: Connection reset by peer.
lxc 20180109093746.743 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/unified//lxc/test2
lxc 20180109093746.798 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/systemd//lxc/test2
lxc 20180109093746.858 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/net_cls//lxc/test2
lxc 20180109093746.914 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/hugetlb//lxc/test2
lxc 20180109093746.974 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/memory//lxc/test2
lxc 20180109093746.102 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/pids//lxc/test2
lxc 20180109093746.107 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/cpuset//lxc/test2
lxc 20180109093746.113 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/cpu//lxc/test2
lxc 20180109093746.119 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/devices//lxc/test2
lxc 20180109093746.126 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/blkio//lxc/test2
lxc 20180109093746.132 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/perf_event//lxc/test2
lxc 20180109093746.139 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/freezer//lxc/test2
lxc 20180109093746.145 ERROR lxc_cgfsng - cgroups/cgfsng.c:recursive_destroy:1286 - Error destroying /sys/fs/cgroup/rdma//lxc/test2
lxc 20180109093746.145 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc 20180109093746.668 ERROR lxc_conf - conf.c:run_buffer:438 - Script exited with status 1.
lxc 20180109093746.668 ERROR lxc_start - start.c:lxc_fini:753 - Failed to run lxc.hook.post-stop for container "test2".
lxc 20180109093746.669 ERROR lxc_criu - criu.c:__criu_restore:1284 - restore process died
stgraber
(Stéphane Graber)
January 9, 2018, 4:14pm
4
What do you have in /var/log/lxd/test2/ ?
CRIU should create one log file per attempt on top of logging to lxc.log.
Hi again,
ubuntu@ibratest-2:~$ ls -lart /var/log/lxd/test2/
total 24824
-rw-r--r-- 1 root root 1775739 Jan 8 13:17 snapshot_dump_2018-01-08T13:17:50Z.log
-rw-r--r-- 1 root root 1774936 Jan 8 13:18 migration_dump_2018-01-08T13:18:17Z.log
-rw-r--r-- 1 root root 1774233 Jan 8 13:18 migration_dump_2018-01-08T13:18:52Z.log
-rw-r--r-- 1 root root 1653936 Jan 8 13:21 migration_dump_2018-01-08T13:21:16Z.log
-rw-r--r-- 1 root root 1654160 Jan 8 13:24 migration_dump_2018-01-08T13:24:06Z.log
-rw-r--r-- 1 root root 1683124 Jan 8 13:36 migration_dump_2018-01-08T13:36:19Z.log
-rw-r--r-- 1 root root 0 Jan 8 13:48 forkexec.log
-rw-r--r-- 1 root root 1682906 Jan 8 15:30 migration_dump_2018-01-08T15:30:33Z.log
-rw-r--r-- 1 root root 1682899 Jan 8 15:30 migration_dump_2018-01-08T15:30:56Z.log
-rw-r--r-- 1 root root 1683046 Jan 8 16:02 migration_dump_2018-01-08T16:02:31Z.log
-rw-r--r-- 1 root root 0 Jan 8 16:37 forkstart.log
-rw-r--r-- 1 root root 1658825 Jan 8 16:42 migration_dump_2018-01-08T16:42:58Z.log
-rw-r--r-- 1 root root 1658862 Jan 8 16:45 migration_dump_2018-01-08T16:45:05Z.log
-rw-r--r-- 1 root root 1663884 Jan 8 16:49 migration_dump_2018-01-08T16:49:14Z.log
drwxr-xr-x 8 root root 4096 Jan 9 06:25 ..
-rw-r--r-- 1 root root 0 Jan 9 08:33 netcat.log
-rw-r--r-- 1 root root 1677111 Jan 9 08:33 migration_dump_2018-01-09T08:33:48Z.log
-rw-r--r-- 1 root root 1676568 Jan 9 09:37 snapshot_dump_2018-01-09T09:37:02Z.log
-rw-r--r-- 1 root root 1676418 Jan 9 09:37 snapshot_dump_2018-01-09T09:37:35Z.log
-rw-r--r-- 1 root root 0 Jan 9 09:37 lxc.log.old
-rw-r--r-- 1 root root 1634 Jan 9 09:37 lxc.conf
drwxr-xr-x 2 root root 4096 Jan 9 09:37 .
-rw-r--r-- 1 root root 4407 Jan 9 09:37 lxc.log
ubuntu@ibratest-2:~$ tail /var/log/lxd/test2/snapshot_dump_2018-01-09T09:37:35Z.log
(03.882616) Unseizing 5294 into 2
(03.882694) Unseizing 5300 into 2
(03.883049) Unseizing 5330 into 2
(03.883418) Unseizing 5332 into 2
(03.883626) Unseizing 5338 into 2
(03.883814) Unseizing 5341 into 2
(03.884138) Unseizing 5443 into 2
(03.884170) Unseizing 5457 into 2
(03.944707) Writing stats
(03.944900) Dumping finished successfully
the log is huge, I’m looking for a way to share it !
stgraber
(Stéphane Graber)
January 10, 2018, 6:55am
7
Can you post the output of lxc info
? That should give us an idea of the liblxc version in use, in case it matters somehow.
lxc info
core.https_address: 10.40.128.12:8443
api_extensions:
- container_stop_priority
- auth_pki
- etag
- patch
- usb_devices
- network
- profile_usedby
- container_push
- gpu_devices
- id_map
- network_routes
- storage
- file_delete
- file_append
- network_vlan
- id_map_base
- file_symlinks
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses:
- 10.40.128.12:8443
architectures:
- x86_64
- i686
certificate: |
certificate_fingerprint: 0acab152caaf6ca62044c634378a55cf061831bf7e514bd47d844aaae8ab0220
driver: lxc
kernel: Linux
server: lxd
server_pid: 14000
storage: zfs
also
dpkg -l | grep lx
ii libgl1-mesa-glx:amd64 17.2.2-0ubuntu1 amd64 free implementation of the OpenGL API -- GLX runtime
ii libgolang-gopkg-lxc-go-lxc.v2-1 0.0~git20161126.1.82a07a6-0ubuntu7 amd64 Go bindings for LXC -- shared library
ii liblxc1 2.1.1-0ubuntu1~ubuntu17.10.1~ppa1 amd64 Linux Containers userspace tools (library)
ii libxcb-glx0:amd64 1.12-1ubuntu1 amd64 X C Binding, glx extension
ii lxc-common 2.1.1-0ubuntu1~ubuntu17.10.1~ppa1 amd64 Linux Containers userspace tools (common tools)
ii lxcfs 2.0.8-1ubuntu2~ubuntu17.10.1~ppa1 amd64 FUSE based filesystem for LXC
ii lxd 2.21-0ubuntu2~17.10.1 amd64 Container hypervisor based on LXC - daemon
ii lxd-client 2.21-0ubuntu2~17.10.1 amd64 Container hypervisor based on LXC - client
stgraber
(Stéphane Graber)
January 11, 2018, 3:33am
9
@brauner do you remember what version of CRIU, LXC and LXD you were using when you got it working last (probably when working with Adrian)?
brauner
(Christian Brauner)
January 11, 2018, 3:05pm
10
I asked Adrian just now but I think we simply used the latest CRIU release and liblxc and LXD from master.
Thank you @brauner and @stgraber
It would be great if you can confirm that some combination is working for you
on the other hand, do you have any estimation of when Live migration will be a non-experimental feature? or it is all in hands of CRIU people?
brauner
(Christian Brauner)
January 18, 2018, 1:19pm
12
That is indeed mostly in the hands of the CRIU people.
adrianr
January 23, 2018, 3:10pm
13
@ibrahim_menem It works perfectly for me with the latest LXC/LXD/CRIU from git. My base system is CentOS VM my containers are alpine and Fedora.
adrianr
January 23, 2018, 8:45pm
14
In the logs you attached I see action-script errors and https://github.com/lxc/lxd/issues/4190 also seems related to CRIU’s action-script. So those two might be related.
