Is it “as designed” to not have a syslog ?
When trying to start syslog.socket ill get the error:
syslog.socket: Socket service syslog.service not loaded, refusing.
Probably is this the cause postfix won’t create a mail.log.
Most containers do run rsyslogd just fine, so you’d have to be a lot more specific about what container you’re running and what’s going on
The Ubuntu container images have syslog.socket and rsyslog.service.
I can do this on LXD and an Ubuntu container image:
ubuntu@steam:~$ sudo systemctl restart syslog.socket
ubuntu@steam:~$
I have 4 LXC’s running with images:debian/9/amd64
They all have there own ZFS storagepool
and they all have no syslog
systemctl status syslog.socket
systemd[1]: syslog.socket: Socket service syslog.service not loaded, refusing.
systemd[1]: Failed to listen on Syslog Socket.
sudo systemctl restart syslog.socket is giving the same result
rsyslog doesn’t appear to be part of the minimal Debian images, did you try to install it?
After installing rsyslog here:
stgraber@castiana:~$ lxc exec debian bash
root@debian:~# ps fauxww
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 75 0.0 0.0 21604 2380 ? Ss 20:21 0:00 bash
root 76 0.0 0.0 40032 2056 ? R+ 20:21 0:00 \_ ps fauxww
root 1 0.0 0.0 56780 4564 ? Ss 20:21 0:00 /sbin/init
root 34 0.0 0.0 46100 5520 ? Ss 20:21 0:00 /lib/systemd/systemd-journald
systemd+ 39 0.0 0.0 48712 2540 ? Ss 20:21 0:00 /lib/systemd/systemd-networkd
root 42 0.0 0.0 4244 944 ? Ss 20:21 0:00 /sbin/ifup -a --read-environment
root 66 0.0 0.0 4292 608 ? S 20:21 0:00 \_ /bin/sh -c /sbin/dhclient -4 -v -pf /run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases -I -df /var/lib/dhcp/dhclient6.eth0.leases eth0 ?
root 68 0.0 0.0 20352 3028 ? S 20:21 0:00 \_ /sbin/dhclient -4 -v -pf /run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases -I -df /var/lib/dhcp/dhclient6.eth0.leases eth0
root 62 0.0 0.0 180484 2040 ? Ssl 20:21 0:00 /usr/sbin/rsyslogd -n
root 63 0.0 0.0 29640 1528 ? Ss 20:21 0:00 /usr/sbin/cron -f
root 65 0.0 0.0 37988 3144 ? Ss 20:21 0:00 /lib/systemd/systemd-logind
message+ 67 0.0 0.0 45124 2292 ? Ss 20:21 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
root@debian:~#
yes i see… just spinned up a ubuntu and syslog is available
Silly me, just needed to install… sorry for the bother, thnx for the quick help!
I is really a beautiful product, love it thnx!
