I need to build incus OpenWRT VM image for arm64 target. I would appreciate if someone could share OpenWRT container distrobuilder yaml configuration file
Hi!
OpenWRT is part of the images provided by the images:
remote, therefore the distrobuilder YAML is available at the lxc-ci
repository, images/
directory.
In order words, the lxc-ci
repository is what is used to generate the images at https://images.linuxcontainers.org/
In that site, the fifth column Build Date is a link to the logs that were generated from the generation of the images. Therefore, you can find in there the exact command-line parameters that were used for the OpenWRT image. Locate the build.log
file in there. The command line looks like
distrobuilder --cache-dir /root/build/cache/ --timeout 7200 build-dir image.yaml rootfs -o image.serial=20241226_11:57 -o image.architecture=aarch64 -o image.release=snapshot -o packages.manager=apk
As you already noticed, there are currently only container images for OpenWRT.
Thanks a lot Simon!
