Hello everyone,
This evening I woke up to begin work on my website, only to find that LXD would fail to start for the following reason.
internal error, please report: running "lxd.lxc" failed: cannot find installed snap "lxd" at revision 11437: missing file /snap/lxd/11437/meta/snap.yaml
Unbeknownst to me, snapd did not save container configuration on re-install. Is the way to recover from this? The container data itself is fine or do I have to recreate 20 containers by hand and risk losing container configuration again?
Distro: openSuSE Tumbleweed
lxc info
config: {}
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses: []
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
certificate_fingerprint: 4db3d927daff9c512945b7753c00ef989c0eec37396b4b54d1dcff059fdf923e
driver: lxc
driver_version: 3.2.1
kernel: Linux
kernel_architecture: x86_64
kernel_features:
netnsid_getifaddrs: "true"
seccomp_listener: "true"
shiftfs: "false"
uevent_injection: "true"
unpriv_fscaps: "true"
kernel_version: 5.2.2-1-default
lxc_features:
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
seccomp_notify: "true"
project: default
server: lxd
server_clustered: false
server_name: linux-iqu9
server_pid: 21798
server_version: "3.15"
storage: ""
storage_version: ""
EDIT: I recovered from earlier snapshot following this guide here https://snapcraft.io/docs/snapshots.
