The jenkins server for LXC shows that there are LXC built for ARM32 and not for ARM64 for Android.
Do you have any plan to build LXC for Android for ARM64 or AARCH64?
If you already have would it be possible to share it?
Thanks
Venkata
Thanks
Venkata
It’s not really something that we use ourselves much, the script we use can be found in https://github.com/lxc/lxc-ci
If you figure it out, we can probably add it to Jenkins easily enough.
