General information
- Distribution:
debian
- Distribution version:
9.9 stretch 64 bit
- The output of
- lxc-start --version
3.1.0-devel
- lxc-checkconfig
Kernel configuration not found at /proc/config.gz; searching...
Kernel configuration found at /boot/config-4.15.18-14-pve
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup v1 mount points:
/sys/fs/cgroup/systemd
/sys/fs/cgroup/cpu,cpuacct
/sys/fs/cgroup/blkio
/sys/fs/cgroup/perf_event
/sys/fs/cgroup/memory
/sys/fs/cgroup/net_cls,net_prio
/sys/fs/cgroup/rdma
/sys/fs/cgroup/pids
/sys/fs/cgroup/cpuset
/sys/fs/cgroup/devices
/sys/fs/cgroup/hugetlb
/sys/fs/cgroup/freezer
Cgroup v2 mount points:
Cgroup v1 clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled
--- Misc ---
Macvlan: enabled, not loaded
Vlan: enabled, not loaded
Bridges: enabled, not loaded
Advanced netfilter: enabled, not loaded
CONFIG_NF_NAT_IPV4: enabled, not loaded
CONFIG_NF_NAT_IPV6: enabled, not loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loaded
FUSE (for use with lxcfs): enabled, not loaded
--- Checkpoint/Restore ---
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities:
- uname -a
Linux nod 4.15.18-14-pve #1 SMP PVE 4.15.18-39 (Wed, 15 May 2019 06:56:23 +0200) x86_64 GNU/Linux
- cat /proc/self/cgroup
12:freezer:/
11:hugetlb:/
10:devices:/system.slice/ssh.service
9:cpuset:/
8:pids:/system.slice/ssh.service
7:rdma:/
6:net_cls,net_prio:/
5:memory:/system.slice/ssh.service
4:perf_event:/
3:blkio:/system.slice/ssh.service
2:cpu,cpuacct:/system.slice/ssh.service
1:name=systemd:/system.slice/ssh.service
- cat /proc/1/mounts
sysfs /sys sysfs rw,relatime 0 0
proc /proc proc rw,relatime 0 0
udev /dev devtmpfs rw,nosuid,relatime,size=16398480k,nr_inodes=4099620,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600,ptmxmode=000 0 0
tmpfs /run tmpfs rw,nosuid,noexec,relatime,size=3283760k,mode=755 0 0
/dev/md2 / ext4 rw,relatime,errors=remount-ro,data=ordered 0 0
securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /dev/shm tmpfs rw 0 0
tmpfs /run/lock tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k 0 0
tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd 0 0
pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0
cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0
cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0
cgroup /sys/fs/cgroup/rdma cgroup rw,nosuid,nodev,noexec,relatime,rdma 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0
cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0
cgroup /sys/fs/cgroup/hugetlb cgroup rw,nosuid,nodev,noexec,relatime,hugetlb 0 0
cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=37,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1356 0 0
mqueue /dev/mqueue mqueue rw,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,relatime 0 0
hugetlbfs /dev/hugepages hugetlbfs rw,relatime,pagesize=2M 0 0
sunrpc /run/rpc_pipefs rpc_pipefs rw,relatime 0 0
fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0
configfs /sys/kernel/config configfs rw,relatime 0 0
/dev/md1 /boot ext4 rw,relatime,errors=remount-ro,data=ordered 0 0
/dev/md4 /tmp ext4 rw,relatime,data=ordered 0 0
lxcfs /var/lib/lxcfs fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other 0 0
/dev/fuse /etc/pve fuse rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other 0 0
Issue description
I create CT container have Centos7.4 OS. when i am trying to enter through the VE host using the following command
lxc-attach -n enter 100
i got error
lxc-attach: enter: attach.c: lxc_attach: 1095 Failed to get init pid
there is no problem with container functionality i can able to access it through ssh well. or console via proxmox GUI. i can start and stop the container without any problem, but i can’t access it through node through lxc-attach command
how can i fix this problem?
regards
