so the error messages have gone…
but the container doesnt start:
michael@indianer2:~$ lxc info --show-log webserver
Remote: unix://
Created: 2018/09/26 20:06 UTC
Status: Stopped
Type: persistent
Profiles: default
Log:
lxc webserver 20190630005254.293 WARN conf - conf.c:lxc_map_ids:2970 - newuidmap binary is missing
lxc webserver 20190630005254.293 WARN conf - conf.c:lxc_map_ids:2976 - newgidmap binary is missing
lxc webserver 20190630005254.349 WARN conf - conf.c:lxc_map_ids:2970 - newuidmap binary is missing
lxc webserver 20190630005254.349 WARN conf - conf.c:lxc_map_ids:2976 - newgidmap binary is missing
lxc webserver 20190630005254.583 WARN conf - conf.c:lxc_setup_devpts:1641 - Invalid argument - Failed to unmount old devpts instance
lxc webserver 20190630005254.925 WARN conf - conf.c:lxc_map_ids:2970 - newuidmap binary is missing
lxc webserver 20190630005254.925 WARN conf - conf.c:lxc_map_ids:2976 - newgidmap binary is missing
michael@indianer2:~$ lxc list
| dbserver | RUNNING | 192.168.1.230 (eth0) | 2001:16b8:30d4:ef00:216:3eff:fe11:c7b8 (eth0) | PERSISTENT | 8 |
| mailserver | RUNNING | 192.168.1.220 (eth0) | 2001:16b8:30d4:ef00:216:3eff:fe59:303f (eth0) | PERSISTENT | 8 |
| mailtools | RUNNING | 192.168.1.240 (eth0) | 2001:16b8:30d4:ef00:216:3eff:fedb:e634 (eth0) | PERSISTENT | |
| webserver | STOPPED | | | PERSISTENT | |
stgraber
(Stéphane Graber)
June 30, 2019, 12:56am
23
lxc console --show-log webserver
Console log:
/sbin/init: error while loading shared libraries: libseccomp.so.2: cannot open shared object file: No such file or directory
is it possible that my conainer is damaged through the power loss?
can i somehow recover a snapshot?
stgraber
(Stéphane Graber)
June 30, 2019, 1:00am
27
Snapshot list is visible in lxc info webserver
The console output above shows that there’s something wrong with that container’s init system, missing library or corrupted init somehow. May be fixable with some more work, but if you have a recent snapshot, restore would be easiest.
michael@indianer2:~$ lxc snapshot webserver pre-restore
Error: subvolume snapshot failed, source=/var/snap/lxd/common/lxd/storage-pools/default/containers/webserver, dest=/var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/webserver/pre-restore, output=ERROR: not a subvolume: /var/snap/lxd/common/lxd/storage-pools/default/containers/webserver
sorry for all these problems… :-/
stgraber
(Stéphane Graber)
June 30, 2019, 1:04am
29
Ok, I wonder if we can make a backup of it with:
lxc export webserver --container-only
That should get you a tarball of whatever is currently on disk, then you can do the lxc restore
knowing you have a copy of the data that was there in case something goes bad.
this also didnt work:
michael@indianer2:~$ lxc export webserver --container-only
Error: Create backup: Backup storage: subvolume snapshot failed, source=/var/snap/lxd/common/lxd/storage-pools/default/containers/webserver, dest=/var/snap/lxd/common/lxd/storage-pools/default/containers/webserver856524048/.backup, output=ERROR: not a subvolume: /var/snap/lxd/common/lxd/storage-pools/default/containers/webserver
michael@indianer2:~$ lxc restore webserver snap6
Error: not found
ok…should it be named michael@indianer2:~$ lxc restore webserver/snap6?
stgraber
(Stéphane Graber)
June 30, 2019, 1:13am
33
nope, lxc restore webserver snap6
is right… can you try with snap5
Ownership of snap6 looked a bit odd in previous listings.
negative…:
michael@indianer2:~$ lxc restore webserver snap5
Error: not found
michael@indianer2:~$ lxc restore webserver snap4
Error: not found
michael@indianer2:~$ lxc restore webserver snap3
Error: not found
michael@indianer2:~$ lxc restore webserver snap2
Error: not found
lxc info webserver
Remote: unix://
Status: Stopped
Type: persistent
Profiles: default
sudo ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/snapshots
ls: cannot access '/var/snap/lxd/common/mntns/var/snap/lxd/common/snapshots': No such file or directory
sudo ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/snapshots/webserver
ls: cannot access '/var/snap/lxd/common/mntns/var/snap/lxd/common/snapshots/webserver': No such file or directory
sudo ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/storage-pool/default/containers-snapshots
ls: cannot access '/var/snap/lxd/common/mntns/var/snap/lxd/common/storage-pool/default/containers-snapshots': No such file or directory
sudo ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/storage-pool/default/containers-snapshots/webserver
ls: cannot access '/var/snap/lxd/common/mntns/var/snap/lxd/common/storage-pool/default/containers-snapshots/webserver': No such file or directory
stgraber
(Stéphane Graber)
June 30, 2019, 1:24am
37
Hmm, lxc info
suggests there are no snapshots in the database for that container.
That seems odd given the state of the filesystem.
lxd sql global "SELECT * FROM containers;"
michael@indianer2:~$ lxd sql global "SELECT * FROM containers;"
| id | node_id | name | architecture | type | ephemeral | creation_date | stateful | last_use_date | description | project_id | expiry_date |
| 1 | 1 | webserver | 2 | 0 | 0 | 2018-09-26T22:06:19+02:00 | 0 | 2019-06-30T02:52:53.911940505+02:00 | | 1 | 0001-01-01T00:00:00Z |
| 2 | 1 | mailserver | 2 | 0 | 0 | 2018-09-26T22:10:35+02:00 | 0 | 2019-06-30T02:40:03.209976254+02:00 | | 1 | 0001-01-01T00:00:00Z |
| 3 | 1 | mailtools | 2 | 0 | 0 | 2018-09-27T08:52:25+02:00 | 0 | 2019-06-30T02:40:04.483494926+02:00 | | 1 | 0001-01-01T00:00:00Z |
| 4 | 1 | dbserver | 2 | 0 | 0 | 2018-09-27T13:34:36+02:00 | 0 | 2019-06-30T02:40:01.949872431+02:00 | | 1 | 0001-01-01T00:00:00Z |
| 29 | 1 | dbserver/20181108 | 2 | 1 | 0 | 2018-11-08T21:22:19.521426735+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 30 | 1 | mailserver/20181108 | 2 | 1 | 0 | 2018-11-08T21:36:57.46488988+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 32 | 1 | dbserver/snap0 | 2 | 1 | 0 | 2018-11-20T10:47:07.368292616+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 33 | 1 | mailserver/snap0 | 2 | 1 | 0 | 2018-11-20T10:47:47.494293777+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 36 | 1 | dbserver/snap1 | 2 | 1 | 0 | 2018-11-27T11:58:50.509550761+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 37 | 1 | mailserver/snap1 | 2 | 1 | 0 | 2018-11-27T11:59:08.227095902+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 40 | 1 | dbserver/snap2 | 2 | 1 | 0 | 2018-12-19T15:47:34.830935276+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 41 | 1 | mailserver/snap2 | 2 | 1 | 0 | 2018-12-19T15:47:51.489952319+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 45 | 1 | dbserver/snap3 | 2 | 1 | 0 | 2019-02-05T11:11:00.587335385+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 46 | 1 | mailserver/snap3 | 2 | 1 | 0 | 2019-02-05T11:11:16.879600768+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 49 | 1 | dbserver/snap4 | 2 | 1 | 0 | 2019-02-19T17:26:24.91316927+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 50 | 1 | dbserver/snap5 | 2 | 1 | 0 | 2019-02-26T10:56:52.229374658+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 51 | 1 | mailserver/snap4 | 2 | 1 | 0 | 2019-02-26T10:57:08.187580399+01:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 54 | 1 | mailserver/snap5 | 2 | 1 | 0 | 2019-04-17T10:01:30.970999331+02:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 55 | 1 | dbserver/snap6 | 2 | 1 | 0 | 2019-05-13T10:48:54.629995947+02:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
| 56 | 1 | mailserver/snap6 | 2 | 1 | 0 | 2019-05-13T10:49:11.351384668+02:00 | 0 | 1970-01-01T01:00:00+01:00 | | 1 | 0001-01-01T00:00:00Z |
seems like there is completely no snapshot for webserver…
stgraber
(Stéphane Graber)
June 30, 2019, 1:27am
40
Yeah, looks like those snapshots you have on disk for the webserver aren’t in the database.
ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/snapshots
ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/snapshots/webserver
ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pool/default/containers-snapshots
ls -lh /var/snap/lxd/common/mntns/var/snap/lxd/common/lxd/storage-pool/default/containers-snapshots/webserver
