Is it possible to create lxc container under double NAT?
You can create a LXC container under double NAT.
The typical difficulty with double NAT is when you want to install specific services inside the container like a VPN. I cannot think of something specific to LXC that would not make it work under double NAT.
Note that it is good to have a specific documented reason to use double NAT.
Thank you for the reply simos. If so how we can implement that. I need to do a testing that client system under double NAT so i created a LXC container which run the client application also i created a bridge (Container attached to that bridge) and try to add the NAT rule on that bridge but it doesn’t helps me. Please give me a tips for this.
Thank you
