I’m running Cuttlefish devices (Android emulator) within LXC containers, and when I try to launch a new device while another device (container) is already running, I encounter the following error:
Port 7100 Bind failed (Address already in use)
Check failed: result.ok() Received `false`
at device/google/cuttlefish/host/commands/run_cvd/launch_streamer.cpp:128
in virtual Result<void> cuttlefish::(anonymous namespace)::StreamerSockets::ResultSetup()
for CF_EXPECT(touch_socket->IsOpen())
Setup failed for StreamerSockets
at device/google/cuttlefish/host/libs/config/feature.cpp:57
in static Result<void> cuttlefish::SetupFeature::RunSetup(const std::vector<SetupFeature *> &)
for CF_EXPECT(feature->ResultSetup())
Received error
at device/google/cuttlefish/host/commands/run_cvd/main.cc:208
in Result<void> cuttlefish::RunCvdMain(int, char **)
for CF_EXPECT(SetupFeature::RunSetup(features))
launch_cvd E 05-14 16:00:13 583 583 subprocess.cpp:160] Subprocess 826 was interrupted by a signal: 6
launch_cvd E 05-14 16:00:13 583 583 main.cc:271] run_cvd returned -1
I thought LXC containers were supposed to be isolated from each other. What could be causing this issue?
maybe some sockets are shared or something ( have no idea what I'm talking about))
