Hello again @tomp , hope you are doing good ,
can you please assist that why i am unable to ping google.com inside my containers , also cant ping host from container
also cant ping another container with its name like ping dev.lxd
Please can you provide the output of lxc config show <instance> --expanded
- this is usually a good start for any post to show what you’re using.
Then also output of ip a
and ip r
on your host and inside the container.
lxc config show dev-brakuschester --expanded
image.architecture: amd64
image.description: Debian stretch amd64 (20200811_05:24)
image.name: debian-stretch-amd64-default-20200811_05:24
image.os: debian
image.release: stretch
image.serial: "20200811_05:24"
image.variant: default
limits.cpu: "1"
limits.memory: 1536MB
volatile.base_image: a833406b9dc1eb5a331d3d0fe73039ceeffde1d17fc423825a619fcac91c3486
volatile.eth0.host_name: veth408bd4de
volatile.eth0.hwaddr: 00:16:3e:d8:7b:b6
volatile.idmap.base: "0"
volatile.uuid: a48804bc-63c0-42ef-b48b-63e1a0f63d97
network: lxdbr0
myport32872:
connect: tcp:127.0.0.1:32872
listen: tcp:0.0.0.0:32872
type: proxy
pool: default
ip a result
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether fa:27:4f:66:37:41 brd ff:ff:ff:ff:ff:ff
inet 194.113.74.149/22 brd 194.113.75.255 scope global dynamic eth0
valid_lft 60727sec preferred_lft 60727sec
inet6 fe80::f827:4fff:fe66:3741/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether fa:27:4f:66:f4:3a brd ff:ff:ff:ff:ff:ff
inet 10.9.6.99/22 brd 10.9.7.255 scope global dynamic eth1
valid_lft 3032sec preferred_lft 3032sec
inet6 fe80::f827:4fff:fe66:f43a/64 scope link
4: eth2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether fa:27:4f:66:2a:4b brd ff:ff:ff:ff:ff:ff
inet6 2605:7380:8000:1000:f827:4fff:fe66:2a4b/64 scope global dynamic mngtmpaddr
valid_lft 86061sec preferred_lft 14061sec
inet6 fe80::f827:4fff:fe66:2a4b/64 scope link
10: lxdbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:f0:2d:4c brd ff:ff:ff:ff:ff:ff
inet 10.9.6.99/22 scope global lxdbr0
inet6 fd42:cb36:ebe:7976::1/64 scope global
inet6 fe80::216:3eff:fef0:2d4c/64 scope link
12: veth5945b1da@if11: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 5e:8d:a0:54:c5:9a brd ff:ff:ff:ff:ff:ff link-netnsid 0
14: veth3a7f119c@if13: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether c6:b7:d6:c3:1a:22 brd ff:ff:ff:ff:ff:ff link-netnsid 1
16: veth408bd4de@if15: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether 3e:b1:68:df:e3:68 brd ff:ff:ff:ff:ff:ff link-netnsid 2
ip r
default via 194.113.72.1 dev eth0
10.0.0.0/8 via 10.9.4.1 dev eth1
10.9.4.0/22 dev eth1 proto kernel scope link src 10.9.6.99
10.9.4.0/22 dev lxdbr0 proto kernel scope link src 10.9.6.99
169.254.169.254 via 10.9.4.1 dev eth1
194.113.72.0/22 dev eth0 proto kernel scope link src 194.113.74.149
And ip a
and ip r
inside your instance too please?
Result inside the container
root@proxy:~# ip a s
13: eth0@if14: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:26:86:3e brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.9.7.35/22 brd 10.9.7.255 scope global dynamic eth0
valid_lft 609sec preferred_lft 609sec
inet6 fd42:cb36:ebe:7976:216:3eff:fe26:863e/64 scope global dynamic mngtmpaddr
valid_lft 3591sec preferred_lft 3591sec
inet6 fe80::216:3eff:fe26:863e/64 scope link
root@proxy:~# ip r
default via 10.9.6.99 dev eth0
10.9.4.0/22 dev eth0 proto kernel scope link src 10.9.7.35
You have the same subnet configured on eth1 and lxdbr0 10.9.4.0/22
, and same address 10.9.6.99/22
This is not valid configuration. You should ensure that the subnet is different on each interface for routing to function correctly.
