After renaming a countainer I had a problem with the IP address. The command ‘hostname -i’ did not return the IP address. I tried to fix it but ended op in deleting the container and making a new copy of another similar container.
But not the copy command freezes. I waited 30 minutes but nothing happens. After CTRL-C’ing the copy the container seems to be created but it was not:
root@oev1 ~ # lxc start kas-groen
Error: Failed preparing container for start: Failed to run: zfs mount tank/containers/kas-groen: cannot open ‘tank/containers/kas-groen’: dataset does not exist
Try lxc info --show-log kas-groen
for more info
root@oev1 ~ # lxc info --show-log kas-groen
Remote: unix://
Created: 2021/01/23 21:41 UTC
Status: Stopped
Type: container
Profiles: kas-little
Snapshots:
snap0 (taken at 2021/01/06 15:29 UTC) (stateless)
Log:
