Hi all, after some days of work and try I ask help.
When I start a new container lxc don’t give any address to the container!
This is my /etc/lxc/default.conf
lxc.network.type = veth
lxc.network.link = lxcbr0
lxc.network.flags = up
lxc.network.hwaddr = 00:16:3e:xx:xx:xx
This is my /etc/default/lxc-net
USE_LXC_BRIDGE=“true”
LXC_BRIDGE=“lxcbr0”
LXC_ADDR=“10.0.3.1”
LXC_NETMASK=“255.255.255.0”
LXC_NETWORK=“10.0.3.0/24”
LXC_DHCP_RANGE=“10.0.3.2,10.0.3.254”
LXC_DHCP_MAX=“253”
This is my ifconfig -a
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.202 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 2001:b07:5d27:bd9a:7ae3:b5ff:fe07:f9d0 prefixlen 64 scopeid 0x0
inet6 fe80::7ae3:b5ff:fe07:f9d0 prefixlen 64 scopeid 0x20
ether 78:e3:b5:07:f9:d0 txqueuelen 1000 (Ethernet)
RX packets 129309 bytes 145649400 (138.9 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 63720 bytes 6429678 (6.1 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device memory 0xef000000-ef01ffff
eth1: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 78:e3:b5:07:f9:d1 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
device memory 0xef060000-ef07ffff
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 2 bytes 164 (164.0 B)
TX packets 2 bytes 164 (164.0 B)
lxcbr0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.3.1 netmask 255.255.255.0 broadcast 0.0.0.0
inet6 fe80::216:3eff:fe00:0 prefixlen 64 scopeid 0x20
ether 00:16:3e:00:00:00 txqueuelen 1000 (Ethernet)
RX packets 24 bytes 1520 (1.4 KiB)
TX packets 14 bytes 1100 (1.0 KiB)
vethQAQT1O: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::fcef:75ff:feb3:4515 prefixlen 64 scopeid 0x20
ether fe:ef:75:b3:45:15 txqueuelen 1000 (Ethernet)
RX packets 13 bytes 998 (998.0 B)
TX packets 17 bytes 1318 (1.2 KiB)
This is my brctl show
bridge name bridge id STP enabled interfaces
lxcbr0 8000.00163e000000 no vethQAQT1O
This is my /etc/network/interfaces
The loopback network interface
auto lo
iface lo inet loopback
The primary network interface
allow-hotplug eth0
iface eth0 inet static
address 192.168.1.202
gateway 192.168.1.254
This is an autoconfigured IPv6 interface
iface eth0 inet6 auto
This is the config of a container
lxc.network.hwaddr = 00:16:3e:f5:fc:a9
lxc.rootfs = /var/lib/lxc/MATTINOCORRETTO/rootfs
lxc.rootfs.backend = dir
Common configuration
lxc.include = /usr/share/lxc/config/debian.common.conf
Container specific configuration
lxc.tty = 4
lxc.utsname = MATTINOCORRETTO
lxc.arch = amd64
Please, can someone give me an indication?
Thanks in advance
