There is plenty of free disk space on my device but when I try to export a container I get an error:
lxc export homekube
results in
Error: Create backup: Backup create: Error adding "/var/snap/lxd/common/lxd/storage-pools/default/backup.551519857/rootfs/root/homekube/docs/images/Rasberry-Pi4-Stack.jpg" as "backup/container/rootfs/root/homekube/docs/images/Rasberry-Pi4-Stack.jpg" to tarball: Failed to copy file content "/var/snap/lxd/common/lxd/storage-pools/default/backup.551519857/rootfs/root/homekube/docs/images/Rasberry-Pi4-Stack.jpg": read /var/snap/lxd/common/lxd/storage-pools/default/backup.551519857/rootfs/root/homekube/docs/images/Rasberry-Pi4-Stack.jpg: no space left on device
However df -h reports lots of free space:
udev 7.8G 0 7.8G 0% /dev
tmpfs 1.6G 1.5M 1.6G 1% /run
/dev/sda2 458G 31G 404G 7% /
tmpfs 7.9G 0 7.9G 0% /dev/shm
tmpfs 7.9G 0 7.9G 0% /sys/fs/cgroup
/dev/loop3 56M 56M 0 100% /snap/core18/2128
/dev/loop4 62M 62M 0 100% /snap/core20/1081
tmpfs 1.0M 0 1.0M 0% /var/snap/lxd/common/ns
/dev/loop5 62M 62M 0 100% /snap/core20/1169
/dev/loop12 100M 100M 0 100% /snap/core/11798
/dev/loop10 33M 33M 0 100% /snap/snapd/13640
/dev/loop0 100M 100M 0 100% /snap/core/11993
/dev/loop1 56M 56M 0 100% /snap/core18/2246
/dev/loop2 73M 73M 0 100% /snap/lxd/21780
/dev/loop13 74M 74M 0 100% /snap/lxd/21858
/dev/loop11 43M 43M 0 100% /snap/snapd/13831
tmpfs 1.6G 0 1.6G 0% /run/user/1000
So, whats is going wrong ? Do i need to increase disk space ? But how ?
