@hobiga, @KYuri what’s the current situation? Did you both manage to solve all remaining issues or is there something we can do for you?
@freeekanayaka in my case issue is completly resolved (problem was not caused by LXD itself, but with DB inconsistency).
As feature request: I think it would be nice to have something opposite to lxd sql global .dump
(for example, lxd sql global .dumprestore
) for recreate DB from scratch and filling it with previously saved values.
Thanks for the follow-up @KYuri. I was trying to be lazy and not have to write a script to convert the dump to a import script.
@freeekanayaka I’m in the process now of converting the dump to a bash script. I’ll report back once I get that ran.
@freeekanayaka Update on my current situation is that after dropping the table, recreating it and converting the dump to an import script, it looks like everything is running. Thank you @KYuri for outlining the steps required. If anyone else needs to perform these steps make sure to add the \ before the " in the dump insert lines. I didn’t do this the first time and got a error trying to start the containers.
