I deployed the development setup for juju and charmed operator SDK by following dev-setup .
OS ubuntu 18.04
lxd version 4.17
charmcraft version 1.2.1
While running charmcraft pack command getting below error:
ubuntu@canonicalsetup:~/aman/charm-jaeger$ charmcraft pack -v
2021-08-27 12:20:57,909 charmcraft DEBUG Starting charmcraft version 1.2.1
2021-08-27 12:20:57,909 charmcraft.main DEBUG Raw pre-parsed sysargs: args={'help': False, 'verbose': True, 'quie
t': False, 'project_dir': None} filtered=['pack']
2021-08-27 12:20:57,919 charmcraft.main DEBUG General parsed sysargs: command='pack' args=[]
2021-08-27 12:20:57,921 charmcraft.main DEBUG Command parsed sysargs: Namespace(bases_index=None, destructive_mod
e=False, entrypoint=None, force=False, requirement=None)
2021-08-27 12:20:57,922 charmcraft.commands.pack DEBUG Working arguments: {'from': PosixPath('/home/ubuntu/aman/charm-jaeg
er'), 'destructive_mode': False, 'entrypoint': None, 'requirement': [], 'bases_indices': None, 'force': False}
2021-08-27 12:20:57,922 charmcraft.metadata DEBUG Parsing '/home/ubuntu/aman/charm-jaeger/metadata.yaml'
2021-08-27 12:20:57,929 craft_providers.lxd.lxc DEBUG Executing on host: lxc --project default profile show local:default
2021-08-27 12:20:58,090 charmcraft.commands.build DEBUG Building for 'bases[0]' as host matches 'build-on[0]'.
2021-08-27 12:20:58,091 charmcraft.commands.build INFO Packing charm 'jaeger-k8s_ubuntu-18.04-amd64.charm'...
2021-08-27 12:20:58,100 craft_providers.lxd.lxc DEBUG Executing on host: lxc remote list --format=yaml
2021-08-27 12:20:58,248 craft_providers.lxd.remotes DEBUG Remote 'craft-com.ubuntu.cloud-buildd' already exists.
2021-08-27 12:20:58,248 craft_providers.lxd.lxc DEBUG Executing on host: lxc project list local: --format=yaml
2021-08-27 12:20:58,402 craft_providers.lxd.lxc DEBUG Executing on host: lxc --project charmcraft list local: --format=ya
ml
2021-08-27 12:20:58,720 craft_providers.lxd.lxc DEBUG Executing on host: lxc --project charmcraft list local: --format=ya
ml
2021-08-27 12:20:58,999 craft_providers.lxd.lxc DEBUG Executing on host: lxc --project charmcraft start local:charmcraft-
jaeger-k8s-2077969-0-0-amd64
2021-08-27 12:20:59,330 charmcraft ERROR charmcraft internal error! LXDError: Failed to start 'charmcraft-ja
eger-k8s-2077969-0-0-amd64'.
* Command that failed: 'lxc --project charmcraft start local:charmcraft-jaeger-k8s-2077969-0-0-amd64'
* Command exit code: 1
* Command standard error output: b"Error: Failed preparing container for start: Failed to run: zfs mount default/containers/charmcraf[11/1123]
aft-jaeger-k8s-2077969-0-0-amd64: cannot open 'default/containers/charmcraft_charmcraft-jaeger-k8s-2077969-0-0-amd64': dataset does not exist\
nTry `lxc info --show-log local:charmcraft-jaeger-k8s-2077969-0-0-amd64` for more info\n" (full execution logs in /home/ubuntu/snap/charmcraft
/common/charmcraft-log-cdx91636)
Traceback (most recent call last):
File "/snap/charmcraft/603/lib/craft_providers/lxd/lxc.py", line 961, in start
self._run_lxc(
File "/snap/charmcraft/603/lib/craft_providers/lxd/lxc.py", line 79, in _run_lxc
return subprocess.run(lxc_cmd, check=check, **kwargs)
File "/snap/charmcraft/603/usr/lib/python3.8/subprocess.py", line 516, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['lxc', '--project', 'charmcraft', 'start', 'local:charmcraft-jaeger-k8s-2077969-0-0-amd64']' returned
non-zero exit status 1.
The above exception was the direct cause of the following exception:
File "/snap/charmcraft/603/lib/charmcraft/main.py", line 347, in main
retcode = dispatcher.run()
File "/snap/charmcraft/603/lib/charmcraft/main.py", line 332, in run
return self.command.run(self.parsed_args)
File "/snap/charmcraft/603/lib/charmcraft/commands/pack.py", line 124, in run
self._pack_charm(parsed_args)
File "/snap/charmcraft/603/lib/charmcraft/commands/pack.py", line 155, in _pack_charm
builder.run(parsed_args.bases_index, destructive_mode=build_args.destructive_mode)
File "/snap/charmcraft/603/lib/charmcraft/commands/build.py", line 357, in run
charm_name = self.pack_charm_in_instance(
File "/snap/charmcraft/603/lib/charmcraft/commands/build.py", line 412, in pack_charm_in_instance
with launched_environment(
File "/snap/charmcraft/603/usr/lib/python3.8/contextlib.py", line 113, in __enter__
return next(self.gen)
File "/snap/charmcraft/603/lib/charmcraft/providers.py", line 253, in launched_environment
instance = lxd.launch(
File "/snap/charmcraft/603/lib/craft_providers/lxd/launcher.py", line 170, in launch
instance.start()
File "/snap/charmcraft/603/lib/craft_providers/lxd/lxd_instance.py", line 441, in start
self.lxc.start(
File "/snap/charmcraft/603/lib/craft_providers/lxd/lxc.py", line 968, in start
raise LXDError(
craft_providers.lxd.errors.LXDError: Failed to start 'charmcraft-jaeger-k8s-2077969-0-0-amd64'.
* Command standard error output: b"Error: Failed preparing container for start: Failed to run: zfs mount default/containers/charmcraft_charmcr
