Hi, i just installed LXC on opensuse, did the subgid, subuid, and created the file into .config/lxc/default.conf with same values /etc/subgids-subuids . i was able to create a container but never run it, googled the error could not fidn any related to opensuse. here is the error.
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2241 0 1258512 65536
lxc-start: start.c: lxc_spawn: 1341 Failed to set up id mapping.
lxc-start: start.c: __lxc_start: 1530 Failed to spawn container "csgo".
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2267 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2267"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/unified//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2269 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2269"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/systemd//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2271 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2271"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/cpu//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2273 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2273"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/memory//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2275 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2275"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/pids//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2277 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2277"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/rdma//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2279 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2279"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/cpuset//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2281 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2281"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/hugetlb//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2283 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2283"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/blkio//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2285 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2285"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/net_cls//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2287 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2287"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/perf_event//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2289 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2289"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/freezer//lxc/csgo
lxc-start: conf.c: lxc_map_ids: 2657 newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [1258512-1324048) not allowed": newuidmap 2291 0 1258512 65536 65536 0 1
lxc-start: conf.c: userns_exec_1: 3825 error setting up {g,u}id mappings for child process "2291"
lxc-start: cgroups/cgfsng.c: recursive_destroy: 1261 Error destroying /sys/fs/cgroup/devices//lxc/csgo
lxc-start: tools/lxc_start.c: main: 368 The container failed to start.```
To be honest i dropped on using LXC anymore, i felt stuck with it without getting help. however give me some minutes, will run it again and report back.
I just installed LXC, and i got same result:
I do not want to sound jumping into conclusions, but i think LXC will not work well, unless i use UBUNTU as host OS.
sudo cat /etc/sub*
lxcuser:1258512:65536
cat .config/lxc/default.conf
lxc.id_map = u 0 1258512 65536
lxc.id_map = g 0 1258512 65536
lxc.network.type = macvlan
lxc.network.macvlan.mode = bridge
lxc.network.flags = up
lxc.network.link = eth0
lxc-start --name test --f
lxc-start: cgroups/cgfs.c: lxc_cgroupfs_create: 909 Could not set clone_children to 1 for cpuset hierarchy in parent cgroup.
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Read-only file system - Failed to delete /sys/fs/cgroup/cpuset/
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Permission denied - Failed to delete /sys/fs/cgroup/blkio/user.slice
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Read-only file system - Failed to delete /sys/fs/cgroup/hugetlb/
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Permission denied - Failed to delete /sys/fs/cgroup/pids/user.slice/user-1000.slice/session-1.scope
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Read-only file system - Failed to delete /sys/fs/cgroup/freezer/
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Read-only file system - Failed to delete /sys/fs/cgroup/rdma/
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Read-only file system - Failed to delete /sys/fs/cgroup/net_cls,net_prio/
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Permission denied - Failed to delete /sys/fs/cgroup/memory/user.slice
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Permission denied - Failed to delete /sys/fs/cgroup/cpu,cpuacct/user.slice
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Permission denied - Failed to delete /sys/fs/cgroup/devices/user.slice
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Read-only file system - Failed to delete /sys/fs/cgroup/perf_event/
lxc-start: cgroups/cgfs.c: cgroup_rmdir: 209 Permission denied - Failed to delete /sys/fs/cgroup/systemd/user.slice/user-1000.slice/session-1.scope
lxc-start: start.c: lxc_spawn: 1286 Failed creating cgroups.
lxc-start: start.c: __lxc_start: 1530 Failed to spawn container "test".
As you see logs, I think this problem is related to accessing cgroup.
Regardless of whether OS is Ubuntu or not, unprivileged container could work.
But in order to make it work well, there are some prerequisite.
Additionally, as I know, macvlan cannot be supported on unprivileged container.
It might be a limitation of the user namespace itself, since the low device you’re attaching to is still on host.
Yea, i do not see that part. I think my system is missing the file pam_cgfs.so , tried to search for it could not find it.
may i ask what is your OS/destro?
Perfect, i have the pakcage loaded now, here is teh current error.
lxc-start --name ubuntu --logfile $HOME/lxc_ubuntu.log --logpriority DEBUG
lxc-start: lxccontainer.c: wait_on_daemonized_start: 754 Received container state "ABORTING" instead of "RUNNING"
lxc-start: tools/lxc_start.c: main: 370 To get more details, run the container in foreground mode.
lxc-start: tools/lxc_start.c: main: 372 Additional information can be obtained by setting the --logfile and --logpriority options.
cat lxc_ubuntu.log
lxc-start 20190104124145.834 INFO lxc_start_ui - tools/lxc_start.c:main:277 - using rcfile /home/lxcuser/.local/share/lxc/ubuntu/config
lxc-start 20190104124145.834 INFO lxc_utils - utils.c:get_rundir:284 - XDG_RUNTIME_DIR isn't set in the environment.
lxc-start 20190104124145.835 WARN lxc_confile - confile.c:set_config_pivotdir:2262 - lxc.pivotdir is ignored. It will soon become an error.
lxc-start 20190104124145.835 INFO lxc_confile - confile.c:set_config_idmaps:1861 - read uid map: type u nsid 0 hostid 1258512 range 65536
lxc-start 20190104124145.835 INFO lxc_confile - confile.c:set_config_idmaps:1861 - read uid map: type g nsid 0 hostid 1258512 range 65536
lxc-start 20190104124145.835 INFO lxc_container - lxccontainer.c:do_lxcapi_start:877 - Attempting to set proc title to [lxc monitor] /home/lxcuser/.local/share/lxc ubuntu
lxc-start 20190104124145.836 INFO lxc_lsm - lsm/lsm.c:lsm_init:48 - LSM security driver AppArmor
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .reject_force_umount # comment this to allow umount -f; not recommended.
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:610 - Adding native rule for reject_force_umount action 0(kill).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:do_resolve_add_rule:276 - Setting Seccomp rule to reject force umounts.
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:614 - Adding compat rule for reject_force_umount action 0(kill).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .[all].
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .kexec_load errno 1.
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:610 - Adding native rule for kexec_load action 327681(errno).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:614 - Adding compat rule for kexec_load action 327681(errno).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .open_by_handle_at errno 1.
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:610 - Adding native rule for open_by_handle_at action 327681(errno).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:614 - Adding compat rule for open_by_handle_at action 327681(errno).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .init_module errno 1.
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:610 - Adding native rule for init_module action 327681(errno).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:614 - Adding compat rule for init_module action 327681(errno).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .finit_module errno 1.
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:610 - Adding native rule for finit_module action 327681(errno).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:614 - Adding compat rule for finit_module action 327681(errno).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:435 - processing: .delete_module errno 1.
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:610 - Adding native rule for delete_module action 327681(errno).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:614 - Adding compat rule for delete_module action 327681(errno).
lxc-start 20190104124145.836 INFO lxc_seccomp - seccomp.c:parse_config_v2:624 - Merging in the compat Seccomp ctx into the main one.
lxc-start 20190104124145.836 INFO lxc_utils - utils.c:get_rundir:284 - XDG_RUNTIME_DIR isn't set in the environment.
lxc-start 20190104124145.836 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc-start 20190104124145.836 DEBUG lxc_start - start.c:setup_signal_fd:288 - Set SIGCHLD handler with file descriptor: 7.
lxc-start 20190104124145.836 DEBUG console - console.c:lxc_console_peer_default:450 - process does not have a controlling terminal
lxc-start 20190104124145.836 DEBUG lxc_conf - conf.c:chown_mapped_root:2830 - trying to chown "/dev/pts/2" to 100
lxc-start 20190104124145.843 INFO lxc_start - start.c:lxc_init:677 - container "ubuntu" is initialized
lxc-start 20190104124145.844 DEBUG lxc_start - start.c:__lxc_start:1501 - Not dropping CAP_SYS_BOOT or watching utmp.
lxc-start 20190104124145.844 INFO lxc_cgroup - cgroups/cgroup.c:cgroup_init:67 - cgroup driver cgroupfs-ng initing for ubuntu
lxc-start 20190104124145.844 DEBUG lxc_cgfsng - cgroups/cgfsng.c:filter_and_set_cpus:456 - No isolated cpus detected.
lxc-start 20190104124145.844 DEBUG lxc_cgfsng - cgroups/cgfsng.c:handle_cpuset_hierarchy:627 - "cgroup.clone_children" was already set to "1".
lxc-start 20190104124145.844 INFO lxc_start - start.c:lxc_spawn:1324 - Cloned CLONE_NEWUSER.
lxc-start 20190104124145.844 INFO lxc_start - start.c:lxc_spawn:1324 - Cloned CLONE_NEWNS.
lxc-start 20190104124145.844 INFO lxc_start - start.c:lxc_spawn:1324 - Cloned CLONE_NEWPID.
lxc-start 20190104124145.844 INFO lxc_start - start.c:lxc_spawn:1324 - Cloned CLONE_NEWUTS.
lxc-start 20190104124145.844 INFO lxc_start - start.c:lxc_spawn:1324 - Cloned CLONE_NEWIPC.
lxc-start 20190104124145.845 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.845 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.845 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.849 INFO lxc_start - start.c:do_start:914 - Unshared CLONE_NEWNET.
lxc-start 20190104124145.850 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.850 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.850 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.855 WARN lxc_cgfsng - cgroups/cgfsng.c:chown_cgroup_wrapper:1465 - Error chmoding /sys/fs/cgroup/unified/user.slice/user-1000.slice/session-1.scope/user/lxcuser/0/lxc/ubuntu: No such file or directory
lxc-start 20190104124145.856 INFO lxc_network - network.c:lxc_create_network_unpriv_exec:2081 - Execing lxc-user-nic create /home/lxcuser/.local/share/lxc ubuntu 8102 veth br0 (null)
lxc-start 20190104124145.857 ERROR lxc_network - network.c:lxc_create_network_unpriv_exec:2109 - lxc-user-nic failed to configure requested network: lxc_user_nic.c: 804: create_db_dir: Failed to create /run/lxc: Permission denied
lxc-start 20190104124145.857 ERROR lxc_start - start.c:lxc_spawn:1385 - Failed to create the configured network.
lxc-start 20190104124145.857 DEBUG lxc_network - network.c:lxc_delete_network:3096 - Deleted network devices
lxc-start 20190104124145.858 INFO lxc_utils - utils.c:get_rundir:284 - XDG_RUNTIME_DIR isn't set in the environment.
lxc-start 20190104124145.858 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc-start 20190104124145.858 ERROR lxc_container - lxccontainer.c:wait_on_daemonized_start:754 - Received container state "ABORTING" instead of "RUNNING"
lxc-start 20190104124145.858 ERROR lxc_start_ui - tools/lxc_start.c:main:368 - The container failed to start.
lxc-start 20190104124145.858 ERROR lxc_start_ui - tools/lxc_start.c:main:370 - To get more details, run the container in foreground mode.
lxc-start 20190104124145.858 ERROR lxc_start_ui - tools/lxc_start.c:main:372 - Additional information can be obtained by setting the --logfile and --logpriority options.
lxc-start 20190104124145.858 ERROR lxc_start - start.c:__lxc_start:1530 - Failed to spawn container "ubuntu".
lxc-start 20190104124145.885 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.885 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.885 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.902 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.902 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.902 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.921 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.921 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.921 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.941 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.941 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.941 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.954 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.954 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.954 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.963 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.963 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.963 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.970 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.970 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.970 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.975 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.975 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.975 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.980 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.980 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.980 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.984 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.984 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.984 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.988 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.988 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.988 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.993 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.993 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.993 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124145.996 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newuidmap" does have the setuid bit set.
lxc-start 20190104124145.996 DEBUG lxc_conf - conf.c:idmaptool_on_path_and_privileged:2516 - The binary "/usr/bin/newgidmap" does have the setuid bit set.
lxc-start 20190104124145.996 DEBUG lxc_conf - conf.c:lxc_map_ids:2604 - Functional newuidmap and newgidmap binary found.
lxc-start 20190104124146.100 INFO lxc_utils - utils.c:get_rundir:284 - XDG_RUNTIME_DIR isn't set in the environment.
lxc-start 20190104124146.101 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc-start 20190104124146.102 INFO lxc_utils - utils.c:get_rundir:284 - XDG_RUNTIME_DIR isn't set in the environment.
lxc-start 20190104124146.103 WARN lxc_monitor - monitor.c:lxc_monitor_fifo_send:111 - Failed to open fifo to send message: No such file or directory.
lxc-start 20190104124146.104 INFO lxc_conf - conf.c:run_script_argv:398 - Executing script "/usr/share/lxcfs/lxc.reboot.hook" for container "ubuntu", config section "lxc".
Yes, i did that, no luck same error, did new install of opensuse and went through all suggestions here again, same error, i think i am going to try lxc on another OS. Thank you all.
