I’m facing with the problem bellow on Yocto Linux with Rocko version of Poky. I created a rootfs on desktop machine and transfered it on my platform.
Kernel version 4.19
$ lxc-start -n mediatek -F
lxc-start: sync.c: __sync_wait: 57 An error occurred in another process (expected sequence number 5) lxc-start: start.c: __lxc_start: 1354 Failed to spawn container “mediatek”. lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/systemd//lxc/mediatek lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/blkio//lxc/mediatek lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/cpu//lxc/mediatek lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/pids//lxc/mediatek lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/hugetlb//lxc/mediatek lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/freezer//lxc/mediatek lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/rdma//lxc/mediatek lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/debug//lxc/mediatek lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/perf_event//lxc/mediatek lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/memory//lxc/mediatek lxc-start: cgfsng.c: recursive_destroy: 1288 Error destroying /sys/fs/cgroup/devices//lxc/mediatek lxc-start: lxc_start.c: main: 366 The container failed to start. lxc-start: lxc_start.c: main: 370 Additional information can be obtained by setting the --logfile and --logpriority options.
I enabled everything LXC needs in kernel(from lxc-checkconfig list)
$ lxc-checkconfig
— Namespaces —
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled — Control groups —
Cgroup: enabled
Cgroup clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled — Misc —
Veth pair device: enabled
Macvlan: enabled
Vlan: enabled
Bridges: enabled
Advanced netfilter: enabled
CONFIG_NF_NAT_IPV4: enabled CONFIG_NF_NAT_IPV6: enabled CONFIG_IP_NF_TARGET_MASQUERADE: enabled CONFIG_IP6_NF_TARGET_MASQUERADE: enabled CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled
FUSE (for use with lxcfs): enabled — Checkpoint/Restore —
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled CONFIG_NETLINK_DIAG: enabled
File capabilities: enabled
From Yocto recipes :
lxc: meta-virtualization 2.0.8
$ ps auxf | grep apparmor
4173 root 0:00 grep apparmor
I hope we find solution to this problem.
