I am tying to find a way to select a specific distro for my container. For example, I would like to create Centos 7.6 container, but
lxc launch images:centos/7/amd64
creates Centos 7.9 container. Is there a way to do that?
The images we build only use currently supported sources I’m afraid.
You could use distrobuilder to create a custom image and import that though.
Take a look at our CI scripts for example distrobuilder config files:
Thanks for speedy answer. I was hoping you still have some old fingerprint somewhere in the repository that I may use.
