Yes, that works after I destroy the dataset.
My concern on this issue is that: it just happened to be not working after a while. Day by day my Jenkins job will build an image and renew the VM. Should there be any root cause on this occasionally issue?
It suggests that when the VM was deleted the ZFS data set was not able to be deleted. If you can capture the scenario when that happens (perhaps because the delete command fails or you get some errors in the log), then we can see if we can find the cause of it.
It only happens one time after my Jenkins job was running the renew VM for more than 2 months (at least once per day).
But once it happens, I can no more renew the VM with the same name on that specific target in the cluster.
