Running into space issues on my default storage pool. Any guidance on how to increase its size would be most appreciated.
Thanks,
Mike Brown
Thanks,
Mike Brown
Hi!
See https://cbrauner.wordpress.com/2017/07/12/storage-management-in-lxd-2-15/
It describes the new functionality for lxc storage
that was added in LXD 2.15 (you have LXD 2.21 so you are covered).
Specifically, you can create additional storage pools and select to place new containers into the new storage pool.
In addition, you can attach extra space to existing containers.
Hi Simos,
Thanks for the pointers.
Best,
Mike Brown
