I have create a new network interface:
lxc network show lxdbr0
ipv4.address: 10.27.158.1/24
ipv4.dhcp: "true"
ipv4.dhcp.ranges: 10.27.158.200-10.27.158.250
ipv4.nat: "true"
ipv4.routing: "true"
ipv6.address: none
ipv6.dhcp: "false"
type: bridge
- /1.0/containers/nextcloud
managed: true
status: Created
locations:
- none
I have attached it to a container has shown. Next the container wouldn’t get an IP over DHCP. After searching around I noticed the container is using netplan. I so ended up editing nano /etc/netplan/50-cloud-init.yaml and adding eth0 with dhcp4: true.
Now I am wondering if it is the way to go or if that can/should be set from the host ?
