Hello LXD crowd, I’ve been playing around with the new clustering and it’s awesome! The fan network implementation is also impressive. GREAT WORK !!
For dev / training purposes, I would like to run a LXD cluster inside a single cloud instance (or VM). So I have setup LXD 3.1 on Ubuntu 18.04 on which I have deployed 3 Ubuntu 18.04 containers to run my 3 nested LXD cluster hosts (from what I have read this should work, correct me if I’m wrong).
My host LXD setup is working fine:
lxc list
| lxd-az1 | RUNNING | 10.1.0.101 (eth0) | | PERSISTENT | 0 |
| lxd-az2 | RUNNING | 10.1.0.102 (eth0) | | PERSISTENT | 0 |
| lxd-az3 | RUNNING | 10.1.0.103 (eth0) | | PERSISTENT | 0 |
lxc network list
| NAME | TYPE | MANAGED | DESCRIPTION | USED BY |
| ens33 | physical | NO | | 0 |
| hostbr0 | bridge | YES | | 3 |
lxc network show hostbr0
ipv4.address: 10.1.0.1/24
ipv4.nat: "true"
ipv6.address: none
type: bridge
- /1.0/containers/lxd-az1
- /1.0/containers/lxd-az2
- /1.0/containers/lxd-az3
managed: true
status: Created
locations:
- none
ip a
inet6 ::1/128 scope host
2: ens33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:50:56:23:1d:e6 brd ff:ff:ff:ff:ff:ff
inet 192.168.168.154/24 brd 192.168.168.255 scope global dynamic ens33
valid_lft 1555sec preferred_lft 1555sec
inet6 fe80::250:56ff:fe23:1de6/64 scope link
3: hostbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether fe:fa:43:f0:8e:fb brd ff:ff:ff:ff:ff:ff
inet 10.1.0.1/24 scope global hostbr0
inet6 fe80::c8fd:f6ff:fe06:e84/64 scope link
5: vethR4DISA@if4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hostbr0 state UP group default qlen 1000
link/ether fe:fa:43:f0:8e:fb brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::fcfa:43ff:fef0:8efb/64 scope link
7: vethP3EPSE@if6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hostbr0 state UP group default qlen 1000
link/ether fe:fc:66:51:23:f9 brd ff:ff:ff:ff:ff:ff link-netnsid 1
inet6 fe80::fcfc:66ff:fe51:23f9/64 scope link
9: vethI18TQI@if8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hostbr0 state UP group default qlen 1000
link/ether fe:fd:5b:32:a3:00 brd ff:ff:ff:ff:ff:ff link-netnsid 2
inet6 fe80::fcfd:5bff:fe32:a300/64 scope link
lxc storage list
| default | | btrfs | /var/snap/lxd/common/lxd/disks/default.img | 6 |
lxc storage info default
info:
driver: btrfs
space used: 1.79GB
total space: 20.00GB
used by:
containers:
- lxd-az1
- lxd-az2
- lxd-az3
images:
- 75068be14e2a11620a7963b920a082ec335fd5b354a348b99ec807bd9cc8363e
- db24c55f847e24dbe60fd665cf8f894ca1ace2d6419ba742f274966b94d4ca30
lxc storage volume list default
| TYPE | NAME | DESCRIPTION | USED BY |
| container | lxd-az1 | | 1 |
| container | lxd-az2 | | 1 |
| container | lxd-az3 | | 1 |
| image | 75068be14e2a11620a7963b920a082ec335fd5b354a348b99ec807bd9cc8363e | | 1 |
| image | db24c55f847e24dbe60fd665cf8f894ca1ace2d6419ba742f274966b94d4ca30 | | 1 |
I then initiated my cluster starting with my first container (lxd-az1) which was initialised with privileged settings:
lxc init ubuntu:18.04 lxd-az1 -c security.nesting=true
Once inside the container, I started the cluster creation and everything seemed fine for the first node:
lxd init
Would you like to use LXD clustering? (yes/no) [default=no]: yes
What name should be used to identify this node in the cluster? [default=lxd-az1]:
What IP address or DNS name should be used to reach this node? [default=10.1.0.101]:
Are you joining an existing cluster? (yes/no) [default=no]:
Setup password authentication on the cluster? (yes/no) [default=yes]:
Trust password for new clients:
Again:
Do you want to configure a new local storage pool? (yes/no) [default=yes]:
Name of the storage backend to use (btrfs, dir) [default=btrfs]:
Would you like to create a new btrfs subvolume under /var/snap/lxd/common/lxd? (yes/no) [default=yes]:
Do you want to configure a new remote storage pool? (yes/no) [default=no]:
Would you like to configure LXD to use an existing bridge or host interface? (yes/no) [default=no]:
Would you like to create a new Fan overlay network? (yes/no) [default=yes]
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]
Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]: yes
core.https_address: 10.1.0.101:8443
core.trust_password: **REDACTED**
cluster:
server_name: lxd-az1
enabled: true
cluster_address: ""
cluster_certificate: ""
cluster_password: ""
networks:
- config:
bridge.mode: fan
managed: false
type: ""
storage_pools:
- config:
source: /var/snap/lxd/common/lxd/storage-pools/local
driver: btrfs
- config: {}
nictype: bridged
parent: lxdfan0
pool: local
lxc cluster list
| NAME | URL | DATABASE | STATE | MESSAGE |
| lxd-az1 | https://10.1.0.101:8443 | YES | ONLINE | fully operational |
But then when I tried to setup the second node, something went wrong with the storage pool creation:
lxd init
What name should be used to identify this node in the cluster? [default=lxd-az2]:
What IP address or DNS name should be used to reach this node? [default=10.1.0.102]:
Are you joining an existing cluster? (yes/no) [default=no]: yes
IP address or FQDN of an existing cluster node: 10.1.0.101
Cluster fingerprint: **REDACTED**
You can validate this fingerpring by running "lxc info" locally on an existing node.
Is this the correct fingerprint? (yes/no) [default=no]: yes
Cluster trust password:
All existing data is lost when joining a cluster, continue? (yes/no) [default=no] yes
Choose the local disk or dataset for storage pool "local" (empty for loop disk):
core.https_address: 10.1.0.102:8443
cluster:
server_name: lxd-az2
enabled: true
cluster_address: 10.1.0.101:8443
cluster_certificate: |
-----BEGIN CERTIFICATE-----
**REDACTED**
-----END CERTIFICATE-----
cluster_password: **REDACTED**
networks:
- config:
bridge.mode: fan
fan.underlay_subnet: 10.1.0.0/24
managed: true
type: bridge
storage_pools:
- config:
source: ""
driver: btrfs
- config: {}
devices: {}
Error: Failed to create storage pool 'local': failed to prepare loop device: bad file descriptor
It seems LXD is unhappy that /var/snap/lxd/common/lxd/storage-pools/local already exists?
I’m kind of stuck at this point, I don’t have this problem when setting up the same cluster outside of LXD (with no nesting).
Any thoughts?
Thanks again for the great work!
